Old May 9th, 2003, 11:30 AM   #1 (permalink)
McLaren F1 2003
Constantly Bored
McLaren F1 2003's Avatar
Send a message via AIM to McLaren F1 2003 Send a message via Yahoo to McLaren F1 2003
I finally advanced my timing...
so yeah i finally advanced my timing, and WOW omg i hella felt it.
it was at 0, so i put it on 15, and yeah it feels awesome.
one question, when you advance it, are your rpms supposed to go up? and when im flooring it, my friend said that a lil bit of white smoke comes out of my muffler. its happens only under hard driving though. could anyone shed some light on this?
anyway, i think everyone should advance their timing, its one of the best 'free' mods
Well, I totaled my B14, so now I have a Eclipse GT. I'm just longing to get back to Nissan...
McLaren F1 2003 is offline   Reply With Quote
Old May 10th, 2003, 02:26 PM   #2 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
white smoke dunno....sure its not grey? that would just be built up carbon. your rpms will go up when you advance it...atleast mine did. i advanced mine to 19 or 20 degrees.
Katana200sx is offline   Reply With Quote
Old May 10th, 2003, 03:42 PM   #3 (permalink)
98 nizmo200sx se
98 nizmo200sx se's Avatar
question......so we need to set it till it knocks then go back alittle till its not knocking
98 nizmo200sx se is offline   Reply With Quote
Old May 10th, 2003, 10:41 PM   #4 (permalink)
McLaren F1 2003
Constantly Bored
mine is at 15 with absolutely no knocking, so i could prolly take it further
Old May 11th, 2003, 08:44 AM   #5 (permalink)
bgriffey
Posts: n/a
100% Correct... then you will be set to optimize the fuel you're using. Then you need to stay with that octane fuel unless you want to readjust.
Old May 12th, 2003, 10:30 PM   #6 (permalink)
Hotrod_NX
Send a message via ICQ to Hotrod_NX Send a message via AIM to Hotrod_NX
Question for a noob guys... I just got my ass spanked by a '92 Civic SiR tonight in the middle of a rainstorm... He got me out on the highway, that was my first mistake... anyway, how much of an edge would advancing my timing 15 degrees on my 91 NX 1600 give me? The guy had me by almost 10 lengths... That's not cool.
Hotrod_NX is offline   Reply With Quote
Old May 12th, 2003, 11:33 PM   #7 (permalink)
barnoun
Driver
Send a message via AIM to barnoun
Doesn't that car have a b16? If it does, all the advancing in the world won't give you an edge....a turbo would
barnoun is offline   Reply With Quote
Old May 13th, 2003, 12:52 AM   #8 (permalink)
Ninety-Nine SE-L
Please Shift Here
Ninety-Nine SE-L's Avatar
Send a message via AIM to Ninety-Nine SE-L
OK, where can I start?
Anyway, I think everyone should advance their timing, its one of the best 'free' mods
if your timing was originally 0, something is wrong. The car SHOULD be 8 ±2 stock. Make sure you put the car in timing mode before you checked by removing the TPS sensors and revving the motor a few times.
This is a bad way to adjust your timing. First off, you need a higher grade of fuel to run advanced timing (I use 93 octane) I also suggest you run 2 tankfulls of the good stuff before you do it. 2nd, Knocking is bad and you won't always hear knocking at idle so if you are trying to advance it to that point, you can go all the way without hearing squat. In order to do the timing, you need a timing light and I suggest you read up on it. I have an article linked at the bottom of my technical section: click here.
15* is high enough, there is nothing to gain by going higher (cept worse fuel economy).
ok, adjusting the timing is good for about 1-2hp, 3 tops. TEN car lengehs!!!! In that case, I'd say about 40+hp will give you the edge. Forget adjusting your timing, if you wanna catch up, you have a few options:
1. Every bolt-on made for the GA16
2. NOS
3. A mild turbo setup
4. complete engine swap
You have a nice car, but I'm sure an NX2000 couldn't keep up, not to mention, I'm willing to bet that SiR had some extra goodies as well.
Ninety-Nine SE-L is offline   Reply With Quote
Old May 13th, 2003, 10:19 AM   #9 (permalink)
McLaren F1 2003
Constantly Bored
i followed AznVirus's tutorial to a 'T' and it was at 0, dont ask me why
Old May 13th, 2003, 10:22 AM   #10 (permalink)
barnoun
Driver
My timing was at 15º I took off the underdrive pulley, checked it, and it was now at 0º Had to set it again.
