Old Mar 24th, 2003, 11:06 PM   #1 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
Send a message via AIM to HKS20DET
burning coolant?
i filled my coolant up to specified level about a week ago. today i check and there is about an inch left in the resevoir (this has happened a couple times now). my thermostat is stuck open, would this have anything to do with my coolant problem? am i burning it or what? i dont see smoke comin out my tail pipe. i think it grew legs and walked away.
HKS20DET is offline   Reply With Quote
Old Mar 24th, 2003, 11:12 PM   #2 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
maybe u have a leak as well??i dont know much about coolant systems though
Katana200sx is offline   Reply With Quote
Old Mar 24th, 2003, 11:47 PM   #3 (permalink)
AVERAGE
Nissan/Mazda Gumshoe
AVERAGE's Avatar
Send a message via MSN to AVERAGE
probably doesnt relate to u but i had the same problem with my car about a year ago, but i could definetly see black smoke everytime i started my car bellowing out of the tailpipe until it warmed up. i changed the thermostat and never had another issue. dont know about the ga .,.
<a href="http://www.chibangin.com"><img src="http://www.chibangin.com/pics/banner.gif" width="440" height="75" border="0"></a>
AVERAGE is offline   Reply With Quote
Old Mar 25th, 2003, 06:38 AM   #4 (permalink)
By Nature
Nissan Fanatic
Send a message via AIM to By Nature
it might have overflowed from the tank...
also check your oil for what the call 'milk shake' symptoms
"Those who stand for nothing, will fall for anything"
2003 VW Jetta 1.8
1998 Nissan Sentra 1.6
By Nature is offline   Reply With Quote
Old Mar 25th, 2003, 08:31 AM   #5 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
nothin dripping on the ground. and i checked my oil already. so the thermostat might do the trick?
Old Mar 25th, 2003, 10:23 PM   #6 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
when coolant burns, it burns as white smoke, or steam, and loosing coolant causes overheating......
black smoke on the other hand is fuel being too rich and burns with less air....
bluish on the other hand is oil from valve stem seals, piston rings, and crankcase ventilation.....
also do some cylinder leakdown tests for possible head gasket leaks....
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Mar 27th, 2003, 09:21 PM   #7 (permalink)
Sentra_Industies
MFCoEJ Juror
How would coolant "burn"? Coolent is water based, it can evaporate, but it cant burn.
If you know your thermostat is stuck open, replace it. It costs $8 at Napa and takes 20 minutes to change if you DONT know what your doing.
U prolly have a leak. Or you blew your headgasket. Did you over heat it???? If so your head gasket is toast and you got some fun ahead of you
Uncorruptable Official Juror of the NissanForums Court of Eternal Justice
Sentra_Industies is offline   Reply With Quote
Old Mar 27th, 2003, 10:47 PM   #8 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
i have the thermostat i just need to get my lazy ass up to do it. had to do my half shaft last weekendand that took up most my time, now i just need to get this done.
-well i filled the coolant up 3 days ago again. now its almost gone again.
-never overheated at all. not even close.
Old Mar 28th, 2003, 03:17 AM   #9 (permalink)
AVERAGE
AVERAGE's Avatar
Old Mar 29th, 2003, 10:36 PM   #10 (permalink)
RomeSentra
Posts: n/a
Lightbulb
There is a great possibility that you have missed a leak in a hose. Check beneath the intake for a small (1/4 - 5/16) hose with coolant residue on it. The leak never leaves a puddle because it drips onto the engine and exhaust. It took me four months to find the leak on my car. It is easiest to see if you are under the car just to the driver's side of center. When you replace the hose, pay a little extra for fuel injection hose - costs a little more, but this one's a real mother to get to.
