Old Mar 24th, 2003, 03:25 PM   #1 (permalink)
ExtremistAS
Posts: n/a
What oil to use?
I just recently bought a 1995 Nissan Sentra GLE witha GA16DE engine. It has about 120000 and I was wondering what oil I should be using in it. I have no idea what oil the owners before me were using. The car booklet recommends 5W-30 but what brand should I use. Also what other things should I do to keep my car in top form. It looks brand new since the owners before me took great care of the car. Do you guys think I have a while left with the car. Is a cold air intake worth getting installed? If so what one? Thanks in advance.
Old Mar 24th, 2003, 04:47 PM   #2 (permalink)
By Nature
Nissan Fanatic
Send a message via AIM to By Nature
As long as you regularly change oil you should be fine. 10-30 is recommended for high mileage engines and thats what I use. I wouldn't recommend switching to synthetic oils as it will prob will open up all seals at this stage. Your car should do you fine service for another 30-50k if maintained properly, but I think aftermarkets parts for it are bit too late
"Those who stand for nothing, will fall for anything"
2003 VW Jetta 1.8
1998 Nissan Sentra 1.6
By Nature is offline   Reply With Quote
Old Mar 24th, 2003, 07:05 PM   #3 (permalink)
SCOOT
Posts: n/a
Talking OIL
I ALWAYS USE MOBILE 30WT
Old Mar 24th, 2003, 08:48 PM   #4 (permalink)
95 SentraB13
Nissan Fanatic
95 SentraB13's Avatar
"but I think aftermarkets parts for it are bit too late"
That's about the most disheartening thing I've heard but I guess it's true. My car has 116,xxx miles and I've only just begun a few mods, only suspension though.
I know the engines are reliable, so you will get 200,000 miles and more. Regular maintenance like changing engine and transaxel fluid, filters, plugs and wires, re-pack wheel bearings, inspect axel boots, fix engine leaks immediately, etc. is your best bet to keeping it in good shape along with replacing older and failing sensors will help maintain good gas mileage. Run the ECU codes for any problems.
As for oil, my car always used regular crude based oil, 5W30 when new but 10w30 now. All the engine seals were replaced under warranty in '99-00 I believe so I'm switching to Synthetic. If I get leaks, well they are there anyway and need to be fixed, just they're gummed up with oil deposits.
I'd use Mobil 1 10W30, mainly because it's the cheapest, especially at Wal-Mart as you can get the 4.5-5L for the same price as the 4L everywhere else. I might switch to Redline or AMSOIL in the future.
UL Pulley | Weapon-R Header | Stromung Exhaust | KYB AGX Struts & Hyperco Springs | Active Tuning RSTB | Progressive Tech RSB
Current B13 Pic's and Mods. | Cardomain Images | NFTuners
95 SentraB13 is offline   Reply With Quote
Old Mar 24th, 2003, 09:33 PM   #5 (permalink)
By Nature
Nissan Fanatic
200k miles for a 4 cylinder gasoline motor is wishful thinking in my opinion... when installing aftermarket parts on engine with 100+k miles I am asumming you do that to increase performance, so then the car will be driven harder decreasing it's life span...
I switched to syn at 30k and replaced front seal and my oil pan gets slightly wet after 3k.
disclaimer:
ga16de is a workhorse no doubt and I am not deterring anyone from their hobby
2003 VW Jetta 1.8
Old Mar 24th, 2003, 09:45 PM   #6 (permalink)
toolapcfan
Your electrical friend
toolapcfan's Avatar
Synthetic oil has the same characteristics as mineral it just takes higher temps to break it down. Switching to synthetic will not cause any problems. Switching back and forth and mixing will not either. I can't vouch for the GA16DE but I know a few people who didn't turbo their SR20's until they had 120K+ on their motors and are still running stong, and SR20's have aluminum blocks, which are not quite as bulletproof as cast iron. So I wouldn't be too leary of bolt ons for it as long as it checks out okay after a thorough check/tune up. I think if it was well cared for and you continue that it'll run forever. You're more likely to wreck it or have it rust out before the engine will quit on you.
Rob '93 SE-R
PM or e-mail me for Progress swaybars $190 shipped, B13 Progress coilovers $1300 shipped and B13 Progress LCA brace $160 shipped.
toolapcfan is offline   Reply With Quote
Old Mar 24th, 2003, 09:58 PM   #7 (permalink)
sentrapower93
Nissan Addict
Use Mobil 1 10w30 & a nissan oil filter that's what i use. 110k miles and doing fine. FWIW i started adding bolt-ons @ 70k miles, it's never too late as long as your motor & tranny are in good shape...
06 1.8s SE Radium: Nismo stb,Nismo rsb,aFe drop-in,HKS Sport catback,tint, 17" Racing Sparcos, Falken ze-512s.
sentrapower93 is offline   Reply With Quote
Old Mar 24th, 2003, 11:07 PM   #8 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
very close to 130,000 and still going strong. about to do a full tune up and also replace the o2 sensors. im thinking about using those new denso o2 sensors since they are resistant to race gas which i run sometimes. i switched to synthetic a few oil changes ago while my engine already had a oil leak....made the oil leak worse but gave me an incentive to fix the problem. your front seal will probably wear out sooner or later bc it seems to on everyone's ga16
Katana200sx is offline   Reply With Quote
Old Mar 25th, 2003, 01:17 PM   #9 (permalink)
Lucino200sx
Nissan Fanatic
Lucino200sx's Avatar
Send a message via AIM to Lucino200sx
USE regular oil and change it eveyr 1500 ~ 2000 miles. The best solution. 200k miles, it's possible, on a Honda maybe more common, but they I'm sure your transmission is slipping like Arnold on ice skate.
1995 200SX SE
2004 CRV LX
2004 Corolla LE
Lucino200sx is offline   Reply With Quote
Old Mar 25th, 2003, 01:52 PM   #10 (permalink)
SangerSE-R
Nissan Fanatic
SangerSE-R's Avatar
Send a message via AIM to SangerSE-R
mobil 1 syn, I don't thinkt the filter matters as much as people say, IMHO
quote:
__________________________________
"stop molesting me, I just wanted to hug"
SHIFT_california Come Join Us!
SangerSE-R is offline   Reply With Quote
Old Mar 25th, 2003, 01:59 PM   #11 (permalink)
johnand
Nissan Fanatic
I can't believe all the negatives on the lifespan of the GA16DE motor. I have about 160K on my B13 w/ GA. When performing the auto to manual swap, I pulled the oil pan to reseal it, as it was seeping VERY slightly and figured it was the most oportuned time to do it. When I pulled the pan I shined a flashlight into the cylinders and I could still see the crosshatching from the factory cylinder honing. My car doesn't burn a drop of oil and that is w/ 10K oil changes using synthetic since about 30K miles. If I didn't find a great deal on the parts to swap in the SR motor, I would see no reason why the motor wouldn't easily go to 300K.
Use a quality name brand oil and change often and you'll be fine. Or switch to synthetic, but be prepared to possibly replace some seals. Synthetic's advantages outweigh that disadvantage as far as I am concerned.
1991 Sentra SE - Auto to Manual swap, 15" Rota Subzero's, 205/50 Kuhmo 712's, Tsuru headlight conversion, SE-R front and rear disc brakes, SE-R front and rear swaybars, SE-R throttle body, SE-R rear inner taillights, HS CAI and Header, H&R springs, Koni shortened struts, ES Hyperflex kit, B&M Short Shifter, Autometer gauges.
johnand is offline   Reply With Quote
Old Mar 25th, 2003, 06:16 PM   #12 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
Mobil 1 with Nissan filter
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Mar 25th, 2003, 08:48 PM   #13 (permalink)
Katana200sx
P.O.S. Truckdriver
im with john. the spare engine i got had 155,000 miles and it had the factory hatchin in the cylinders as well. only thing wrong w/the bottom end was the pistons had alot of carbon buildup which is normal. doubt there's alimit to how long an engine can run anymore w/proper maintanence. most of the time you either wreck it, trade it, or somethin else major goes wrong before the actual engine.
Old Mar 26th, 2003, 11:32 PM   #14 (permalink)
HCS200sx97
Send a message via AIM to HCS200sx97
Just keep in mind synthetics clean the engine a lot, including deposits on seals which keep them from leaking. Best to usually waiver on the side of caution unless your low miles, low years, or have a knack for replace many seals.
Also there is a very similar thread in the b14 section on this same topic. Check it out for some incite.
-Kyle
HS CAI, 16" Rota Subzeros w. Khumo ECSTA Supra 712s, JWT 7lb Flywheel
HCS200sx97 is offline   Reply With Quote
Old Mar 27th, 2003, 11:20 AM   #15 (permalink)
MontyCrabApple
Nissan Fanatic
Yeah, use mobil 1 10W-30, that's what I use on my 1994 Sentra XE with 92,000 miles. As for oil filters, I get Fram or K&N.
As for upgrdes, I went to checker and bought a $20 cone filter, went to Home Depot and bought an adapter to connect the air filter to the MAF, and attached all that direcly on to the stock air intake tube. Good to give you like 1-2 extra horses plus the engine sounds more throaty.
Don't deny headers or exhaust either. You can put that on with out worrying about anything major.
My car's heading towards the big 100 on my odometer too, and iv'e already replaced the crank oil seal and the outer cv boots, but the car still pulls strong.
Oh yeah, check up on a Hyper Ground System set. The kit cost a $100 and comes with wires to ground your car properly giving you more horses. I did a post on this, don't know if it's still up, so do a search under "proper grounding +16 hp."
MontyCrabApple is offline   Reply With Quote
