No Spark - Nissan Forum
post #1 of 5 Old Feb 17th, 2013, 05:59 PM Thread Starter
No Spark
So im driving down the road, and everything is fine. suddenly the engine hiccups and then dies all together. i get it home and check all the ignition troubleshooting steps given in the hanyes manual. everything checks good. i use an spark checker and i have no spark. i even set the gap a little smaller in case its a weak spark. but nothing. any ideas?
marcom1234 is offline
post #2 of 5 Old Feb 17th, 2013, 06:15 PM Thread Starter
oh and its a 1997 nissan sentra gxe
post #3 of 5 Old Feb 17th, 2013, 11:14 PM
jdg
The Judge!
Pull the distributor cap and see if the rotor is still attached to the shaft or if it spins freely...
99% of the questions that are "STRANGE" have a dirt simple answer...usually answered by a dirt simple search.
Is it just me, or does the majority overlook the obvious?
Somebody ate a whole bag of dumbass for breakfast.
Why do people continue to run a vehicle when a warning light comes on or starts flashing? Isn't that a clue that something is wrong and you probably should NOT drive it?
Is this whole car driving thing really freekin' brain surgery?
Here's something new for the crowd/clowns...
"A little bit of Google goes a long way!"
Ever notice the one post wonders for info on turbo'ing a GA16 are never heard from again after they figure out the cost???
And if you can read this, you don't need glasses! :)
And yes, I am diggin' it...
jdg is offline
post #4 of 5 Old Feb 18th, 2013, 02:49 AM
wilburk's Avatar
Definitely sounds like some distributor shenanigans...
wilburk is offline
post #5 of 5 Old Feb 18th, 2013, 03:00 AM
jdg
The Judge!
Ya, it's happened to me three times now.
First time, I had the car towed 'cause I didn't bother checking the obvious and figured it was catastrophic engine failure because of the way the intake/exhaust sounded while I was cranking it. 6 hours and $300 tow... Decided to take a look-see while I was waiting for a ride and found the rotor screw laying in the cap.
Second time, same car, I was a tad bit smarter and only a mile from the house - 15 minutes and $0. Replaced the distributor anyways 'cause the threads were shot and no amount of lock-tite was gonna do it.
Third time was in the other Sentra, same thing...welded the screw hole shut, drilled and re-tapped it, good to go. Should've given that one a bit of preventative maintenance with some lock-tite, but blew it off...
jdg is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
