1994 sentra cyl. head rebuild, runs rough, loud intake - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Jan 3rd, 2013, 11:18 AM   #1 (permalink)
Send a message via Skype™ to SEGA
noob here. yes read sticky even though it's 10 years old. Anyway-
I'll just give you the background. My Sentra had 196k miles and engine was perfect. My sister somehow lost the radiator cap and overheated it multiple times and warped the head and blew the head gasket. The head would have cost too much to be re-machined, so I got a used one at a junkyard, and had that one machined.
I did all of the work myself, but had a mechanic fix the electrics, and get it to start.
He told me the cam timing was probably off and that it was running rough, and I asked him to fix it. I got it back yesterday but it was still running a little rough. I trust the guy who did it because he's my dad's friend and has worked on my car before but there's still an issue.
TLR;
Engine runs a little rough when warm and cold, it seems like it has a bit less power and I think it's running rich. The engine sounds like it's missing, but at random intervals. Also, the intake makes a loud BRAAP sound. If anything I want to get this worked out so people don't think I drive a Civic.
SEGA is offline   Reply With Quote
Old Jan 3rd, 2013, 11:25 AM   #2 (permalink)
just a followup:
I'm worried about the cam timing because the intake makes a lot of noise when the throttle is open, but it's just an amateur's guess.
Old Jan 3rd, 2013, 02:18 PM   #3 (permalink)
Have you done a compression test?
Konfewzin is offline   Reply With Quote
Old Jan 3rd, 2013, 02:30 PM   #4 (permalink)
Cool
Not after the rebuild, but I will. I was wary of my results when I did a compression test before I rebuilt the head and if I remember correctly, all cylinders except for cylinder 3 were roughly 90 PSI, and 3 was lower than that- of course, those numbers were registered when the engine was cranking with the starter motor.
I'll test it tonight if I get the chance, but I'm definitely not pulling the block apart anytime soon
Old Jan 3rd, 2013, 02:43 PM   #5 (permalink)
It sounds like you might need rings. I don't know what the spec is but 90 psi seems low and one cylinder lower than the other 3 shows that the rings are worn. You said you did this before the head job though, was this after the head gasket went? A leak in the head gasket can also give a lower psi when testing. If it was overheated multiple times to the point where the head cracked I would suggest a full rebuild or just replace the motor with a used one, for what a rebuild with machine work would cost you can get a running ga16 cheaper at a scrap yard or on ebay. What did the oil look like when you drained it? Was it full of coolant? Did you drop the oil pan and see if anything was gummed up from the head gasket leak? The only times I've heard an engine that matches your description for the "braap" sound along with the misfire, running rich, and lack of power, it was a dead cylinder.
Old Jan 3rd, 2013, 02:45 PM   #6 (permalink)
Also, when you check the compression again, after you test all 4 dry squirt some oil into the cylinder and then test again. If you get higher results when they're wet it usually means you need rings.
Old Jan 3rd, 2013, 05:14 PM   #7 (permalink)
I tested compression after the head blew. Also, the oil didn't have any coolant as far as I could tell, and I didn't drop the pan but I don't think that matters. Cylinder 3 had a little coolant in it, so I figured it was the blown head that caused the low compression. The compression spec is around 180 or 200 PSI I believe.
The head didn't crack, so I think the bottom end is ok.
When the head blew, the major symptom was overheating, but right now it's running worse than it did before I rebuilt it (minus the overheating, lol)
Old Jan 3rd, 2013, 06:00 PM   #8 (permalink)
jdg
The Judge!
Vacuum leak...check it...Find it...Fix it...
99% of the questions that are "STRANGE" have a dirt simple answer...usually answered by a dirt simple search.
NISSAN GOOGLE
Is it just me, or does the majority overlook the obvious?
Somebody ate a whole bag of dumbass for breakfast.
Why do people continue to run a vehicle when a warning light comes on or starts flashing? Isn't that a clue that something is wrong and you probably should NOT drive it?
Is this whole car driving thing really freekin' brain surgery?
Here's something new for the crowd/clowns...
"A little bit of Google goes a long way!"
Ever notice the one post wonders for info on turbo'ing a GA16 are never heard from again after they figure out the cost???
And if you can read this, you don't need glasses! :)
And yes, I am diggin' it...
jdg is online now   Reply With Quote
Old Jan 3rd, 2013, 06:22 PM   #9 (permalink)
that was another possibility I was looking into. will do
Old Jan 3rd, 2013, 09:18 PM   #10 (permalink)
I went out and recorded some video of the symptoms, because why not?
Old Jan 3rd, 2013, 09:19 PM   #11 (permalink)
here's a playlist since the other link didn't work
Old Jan 3rd, 2013, 09:21 PM   #12 (permalink)
welp.
Old Jan 5th, 2013, 05:42 PM   #13 (permalink)
In other news, I checked the compression and got roughly 130 PSI from each cylinder, 170 when I put oil in them. Also, I cleaned the MAF but that didn't go well, (I.E. I broke it)
I just pulled the engine light codes, which are 12 and 14. Vehicle Speed Sensor and MAF, respectively.
well, shoot.
Old Jan 5th, 2013, 06:03 PM   #14 (permalink)
It's hard to hear the sound you're describing. In the video it just sounds like you opened up the intake. Do you have a tach you could point the camera at instead of the speedo so I could tell what's going on? When you let off and you mentioned a lunge it sounded like you just let off the gas leaving the car in gear and usually this will cause a "lunge" from engine braking but I can't tell if that's what happened or not. When the maf my nx went out it wouldn't rev past 2500 rpm or something like that and misfired.
Old Jan 5th, 2013, 06:52 PM   #15 (permalink)
My MAF just barely went out, and it won't rev past whatever it is, my tach is broken.
I'm just going to assume that the loud intake is a just a quirk, since the cams are from a b14. By lunge, I mean it would lunge more than once, but I guess that symptom doesn't mean much. I need to get a new MAF and test the VSS, and go from there.
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
