1994 sentra cyl. head rebuild, runs rough, loud intake - Page 2 - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Jan 5th, 2013, 07:12 PM   #16 (permalink)
It's shitty quality but this is how my ga16de sounds in my 93 nx I don't know if seeing/hearing another one helps but this is also just in neutral on jack stands.
The cams could be making the noise difference, if you pop the hood and watch the engine when you rev it does it stumble and shake? If you go wot does it hesitate or choke before revving? The b14 cams have a slightly larger lobe separation for more top end power, I would assume it would give a slightly louder noise over a stock b13, but I have never actually done the swap so I wouldn't know for sure. When you take off in gear does it pull smooth all the way to the rev limiter or does it start to get jerky when it starts making noise?
Konfewzin is offline   Reply With Quote
Old Jan 5th, 2013, 10:32 PM   #17 (permalink)
jdg
The Judge!
Originally Posted by SEGA View Post
In other news, I checked the compression and got roughly 130 PSI from each cylinder, 170 when I put oil in them. Also, I cleaned the MAF but that didn't go well, (I.E. I broke it)
I just pulled the engine light codes, which are 12 and 14. Vehicle Speed Sensor and MAF, respectively.
well, shoot.
You said you just got this motor rebuilt?
How many miles are on it? 130 might not be that low if the rings aren't seated yet. Yes, it's a bit low even if the rings aren't seated, but, if you've got low miles on it, I'd expect that number would come up after awhile.
99% of the questions that are "STRANGE" have a dirt simple answer...usually answered by a dirt simple search.
NISSAN GOOGLE
Is it just me, or does the majority overlook the obvious?
Somebody ate a whole bag of dumbass for breakfast.
Why do people continue to run a vehicle when a warning light comes on or starts flashing? Isn't that a clue that something is wrong and you probably should NOT drive it?
Is this whole car driving thing really freekin' brain surgery?
Here's something new for the crowd/clowns...
"A little bit of Google goes a long way!"
Ever notice the one post wonders for info on turbo'ing a GA16 are never heard from again after they figure out the cost???
And if you can read this, you don't need glasses! :)
And yes, I am diggin' it...
jdg is offline   Reply With Quote
Old Jan 6th, 2013, 03:32 AM   #18 (permalink)
b13er's Avatar
Garage
Please explain how you broke your MAF, I would love to hear about it... Did you use carburetor cleaner instead of CRC mass air flow sensor cleaner?
I broke my VTC valve trying to take it out, but got a new one at Pull Apart for $6.
b13er is offline   Reply With Quote
Old Jan 6th, 2013, 03:34 AM   #19 (permalink)
Mine just randomly stopped working on the highway around 245k.
Old Jan 6th, 2013, 02:38 PM   #20 (permalink)
b13er's Avatar
Garage
I would use the field service manual to try and solve your problem. If you type
sentra fsm
in google. The first two links will have the fsm's for download.
Go to the EC document and look at the fifth section under GA that says "Trouble Diagnoses". The index for that will have a section for Diagnostic Procedure - Symptom - Unstable Idle, and you might want to check out Backfire Through Intake.
Old Jan 22nd, 2013, 11:39 AM   #21 (permalink)
Send a message via Skype™ to SEGA
Fixed it.
Part of the problem was the resonator had a disconnected vacuum hose, but I think that happened when I pulled out the MAF. I did the ignition timing, and swapped out the IACV with a different one I had. Next step is swapping out the clutch cable. The aftermarket one I have is too long even when adjusted, and the clutch disengages only when the pedal is right on the floor.
SEGA is offline   Reply With Quote
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
