timing chain cover help! - Nissan Forum
post #1 of 2 Old Jan 13th, 2012, 05:47 PM Thread Starter
So i am working on a 97 sentra. Its leaking oil and i have just replaced the front main seal it dont leak from there anymore. But what i noticed is that there is a leak coming from the timing chain cover next to where the power steering pump is located. My question is, what do i have to remove to take the timing cover off? is there bolts inside the head that requires me to remove the valve cover? i really need help its driving me nuts!!
krayzie7th is offline
post #2 of 2 Old Jan 13th, 2012, 09:22 PM
NF Mod/Nissan Master Tech
smj999smj's Avatar
Do a search for Nissan TSB # NTB98-107 and it'll give you the (then) updated R&R procedure. I'll copy it below, but the images won't appear. You can also try finding the R&R procedure at Autozone.com. They have free repair guides there; all you need to do is register your e-mail address.
Classification:
EM98-009
Reference:
NTB98-107
Date:
January 15, 1999
GA16DE TIMING CHAIN/FRONT COVER
REVISED SERVICE PROCEDURE
APPLIED ENGINE:
GA16DE
APPLIED MODELS:
1991-94 Sentra (B13) w/GA16DE
1991-93 NX1600 (B13)
1995-99 Sentra (B14) w/GA16DE
1995-98 200SX (B14) w/GA16DE
SERVICE INFORMATION
A revised service procedure for the engine front cover/timing chain has been adopted for the GA16DE. It is no longer recommended to remove the cylinder head when removing the timing chain/front cover(s). Utilize the following steps when servicing the front cover, timing chain, guides or tensioner(s)
Caution
^ After removing the timing chain, do not turn the crankshaft and camshaft separately or the valves will strike the piston heads.
^ When installing chain tensioners or other sliding parts, lubricate contacting surfaces with new engine oil.
^ Apply new engine oil to bolt threads and seat surfaces when installing the camshaft sprockets and the crankshaft pulley.
^ Do not spill engine coolant on the drive belts.
^ Please refer to the Service Manual for the correct tightening torque.
__________________________________________________ ________________________
Removal
1. Set # 1 piston at TDC on its compression stroke.
2. Remove the spark plug wires.
3. Remove the rocker cover (see Figure 1).
4. Remove the coolant reservoir tank with bracket and reposition it for clearance.
5. Support the engine with a suitable jack.
6. Remove cylinder head front mounting bracket.
7. Remove engine front mounting, then the engine front mounting bracket.
8. Remove cylinder head front cover.
9. Remove the upper chain tensioner (see Figure 2).
10. Wipe off the links of the upper timing chain next to the timing marks on the sprockets. Put paint marks on the timing chain, matching them with the timing marks on the cam sprockets and idler sprocket (see Figure 3)
11. Remove the four (4) front cover to cylinder head bolts.
12. Remove side and lower engine compartment splash covers.
13. Remove the accessory drive belts.
14. Remove the crankshaft pulley.
15. Drain coolant by removing the cylinder block drain plug and opening the radiator drain cock (Refer to MA section of the Service Manual).
16. Drain engine oil.
17. Remove intake manifold support of engine front side.
18. Remove power steering pump, pump bracket and tension rod. Position pump aside for clearance.
19. Remove the thermostat housing (See Figure 4).
20. Remove the lower chain tensioner (see Figure 5).
21. Remove the front exhaust tube. Refer to the "FE" section (Exhaust System) of the Service Manual.
22. Remove the front and rear engine gussets (if equipped) on either side of the oil pan.
NOTE: On A/T models, remove the rear plate cover.
23. Remove the oil pan (see Figure 6).
a. Insert the Tool between the cylinder block and oil pan.
CAUTION: Be careful not to damage the aluminum mating face. Do not insert a screwdriver, or the oil pan flange will become damaged.
b. Slide the Tool by tapping it on the side of the Tool with a hammer.
24. Remove the A/C compressor and position it aside for clearance.
25. Remove the A/C and alternator bracket with the alternator.
26. Remove the oil pump drive spacer.
CAUTION: Be careful not to scratch the drive spacer when removing it.
27. Remove the front cover bolts and front cover.
CAUTION: One bolt is located on the water pump (see Figure 7).
*1: Located on engine front mounting bracket.
*2: Located on the water pump.
*3: Located on the power steering oil pump adjusting bar.
CAUTION: Be careful not to tear or damage the cylinder head gasket.
28. Remove the cylinder block to front cover alignment dowels.
CAUTION: Do not hit the dowels or the cylinder block will crack.
29. Wipe off the links of the lower timing chain next to the timing marks on the sprockets. Put paint marks on the timing chain, matching them with the timing marks on the idler sprocket and crankshaft sprocket (see Figure 8).
Installation
1. Install the crankshaft sprocket, making sure the mating marks face the front of the engine.
2. Install the idler sprocket and lower timing chain using the mating marks and the paint marks made during the removal process.
3. Install the lower chain guides.
4. Front cover installation:
a. Using a scraper or other suitable tool remove all traces of liquid gasket from the cylinder block and front cover mating surfaces.
b. Install new crankshaft seal in front cover.
c. Install new oil passage O-rings and apply a continuous bead of RTV sealant to the front cover (see Figure 1).
NOTE: Use Genuine Nissan RTV silicone sealant P/N 999MP-A7007, Three Bond P/N TB1207D or equivalent.
d. Install the front cover to the engine.
CAUTION: Be careful not to tear or damage the cylinder head gasket or oil seal.
5. Align oil pump drive spacer with the oil pump, and install.
6. Install the oil strainer.
7. Install oil pan, referring to "Installation" in the "OIL PAN" section of the Service Manual.
8. Install upper timing chain and sprockets, using the painted reference marks made during removal.
9. Install upper chain tensioner.
a. Before installing the chain tensioner, insert a suitable pin into the pin hole of the chain tensioner (see Figure 2) to hold the tensioner in.
b. Once the tensioner is installed, remove the pin.
10. Install the lower chain tensioner (See Figure 3).
NOTE: Make sure the gasket is facing the proper direction before installing the tensioner.
CAUTION: Now rotate the crankshaft by hand. Check that no binding or interference problems occur when the engine is rotated.
11. Install the thermostat housing.
a. Use a scraper to remove all traces of liquid gasket from the mating surfaces of the engine front cover and the thermostat housing.
b. Apply a continuous bead of RTV sealant to the housing as shown in Figure 4.
12. Install camshaft sprocket cover:
a. Use a scraper to remove all traces of liquid gasket from the mating surfaces of the cylinder head and camshaft sprocket cover.
b. Apply a continuous bead of RTV sealant to the cover as shown in Figure 5.
d. Install camshaft sprocket cover.
13. Apply RTV sealant to rocker cover gasket (see Figure 6a) and install rocker cover, tightening the bolts as shown in Figure 6b.
14. Install the following parts:
a. Crankshaft pulley.
b. A/C compressor and alternator bracket with alternator.
c. A/C compressor.
d. Power steering oil pump and tension rod.
15. Install front and rear engine gussets (if equipped), and rear cover plate (A/T models).
16. Install front exhaust tube.
17. Install upper right engine bracket and mount.
18. Install coolant reservoir tank.
19. Install alternator, power steering and A/C compressor drive belts.
20. Install engine compartment splash guards.
21. Install vacuum hoses, electrical harnesses and connectors.
22. Install spark plug wires.
23. Refill with coolant. Refer to the "MA" section ("Changing engine coolant, Engine Maintenance") of the Service Manual.
24. Refill with engine oil. Refer to the "MA" section ("Changing engine oil, Engine Maintenance") of the Service Manual.
smj999smj is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
