Spark Plug tube seals replacement issue! - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Dec 20th, 2011, 04:18 PM   #1 (permalink)
I replaced the valve cover gasket but have an issue with the spark plug tube seals. Can someone please help me with the installation of the spark plug tube seals. I am trying to get them out of the valve cover assembly but can not. It looks like there is a piece that is glued or something inside the valve cover but not sure. The tube seals I am replacing are dry rotted and they are crumbling when taking them out. Any help will be greatly appreciated.
ericmckinney is offline   Reply With Quote
Old Dec 20th, 2011, 10:25 PM   #2 (permalink)
NF Mod
Send a message via AIM to smj999smj
I've always just used a seal puller to pull them out, like Lisle tools P/N: 56650.
smj999smj is offline   Reply With Quote
Old Dec 21st, 2011, 08:45 AM   #3 (permalink)
I understand that I can use a seal puller but what I am saying is where they are installed in the valve cover they will not come out without tearing them up because the seal do not flex and bend to get them out and then for the new ones to be installed I can not damage them to get them in. When you take the valve cover of and you turn it over there is like a light brown plate on the underside of the valve cover and it looks like it comes off so you can get the old seal out and the new seals installed with ease. Is this true. Please let me know because I do not need to cause anymore damage then I have to. Thanks for any help.
Old Dec 21st, 2011, 11:22 AM   #4 (permalink)
NF Mod
Assuming we are talking about a B14 Sentra, I've never had to take any cover off of the bottom side of the valve cover to remove spark plug tube seals. They should be sitting in a slight recess for the seals. If they are brittle, spraying them with some carb cleaner might soften them up a little. The only plate on the bottom of the valve cover that I can think of is the baffle plate for the PCV, which shouldn't be in the way of the spark plug tube seals.
Old Dec 29th, 2012, 01:01 AM   #5 (permalink)
wilburk's Avatar
Ok so I know this is a dated post, but I just replaced my valve cover gasket (along with a bunch of other things).
You can't replace the spark plug gaskets because they're under the piece of plastic on the underside of the cover. Found this out the hard way when I stabbed through them on accident with a screwdriver trying to replace them.
A good cleaning should do--otherwise, hit pull-a-park for a cheap replacement cover.
wilburk is offline   Reply With Quote
Old Jan 4th, 2013, 01:05 AM   #6 (permalink)
b13er's Avatar
Garage
I checked rockauto.com and they sell kits that come with the valve cover spark plug seals for both the b13 and b14: More Information for BECK/ARNLEY 0361823
I wish I knew if you all were talking about a b14 or a b13 or what, because I was planning on replacing mine since I always see oil in my spark plug tubes.
b13er is offline   Reply With Quote
Old Jan 4th, 2013, 01:56 AM   #7 (permalink)
wilburk's Avatar
All gasket replacement kits come with spark plug gaskets, even though you can't replace them. I don't know why.
Here's a picture of the underside of my cover.
You can see the spark plug gaskets--it looks like they would be replaceable, but they're not. They're attached UNDER that piece of orange plastic.
So if your spark plug tubes have oil in them, I would recommend doing one of two things:
1. Clean the seal, and then patch up any tears with RTV
2. Just get a new cover--they're like $30 at the junkyard
Hope that helps...
Old Jan 4th, 2013, 06:47 AM   #8 (permalink)
NF Mod
I would just use some brake cleaner and a rag to clean the oil off of the seals and the spark plug tube, put a thin layer of RTV silicone on the seal and put it together before I'd purchase a junk yard cover. Chances are the junkyard part isn't much better than what you have already. Always replace that small, rectangular PCV baffle gasket shown in the picture. Their famous for failing and causing oil to get sucked directly into the engine, making a real mosquito killer!
Old Jan 4th, 2013, 11:54 AM   #9 (permalink)
wilburk's Avatar
Also wouldn't hurt to do a little cleaning of some of the sludge that's accumulated.
Old Jan 28th, 2013, 08:10 PM   #10 (permalink)
Hope that helps...
I had the same problem but I will make an attempt to provide a fix. I did a temporary fix but not sure if it will work at this time but I should be able to come up with something better. I will order more seals and report back.
que4dog is offline   Reply With Quote
Old Jan 29th, 2013, 12:53 AM   #11 (permalink)
wilburk's Avatar
Tell us about your temporary fix...Was it just silicone sealant?
Old Jan 29th, 2013, 12:34 PM   #12 (permalink)
I purchased the gasket with seals and modified the seals by placing grooves and curving out some of the old seal. I didn't do a good job but have an idea for my next attempt. I purchased more seals and will take pictures.
Old Jan 29th, 2013, 03:02 PM   #13 (permalink)
600+ posts
BeyondBiscuits2's Avatar
Send a message via MSN to BeyondBiscuits2 Send a message via Yahoo to BeyondBiscuits2
In my experience with the GA16DE, it is much easier to go to a salvage yard and pick up the aluminium valve cover from the '91-'94 Sentra models. They have the screw-in style PCV (better design, and not prone to popping out), as well as serviceable spark plug tube seals. Plus, they are metal and not the hard plastic Nissan used in the B14 models. All in all, much better!
The Sentra Channel: http://www.youtube.com/thesentrachannel
Subscribe Today!
1990 Nissan Sentra B12 GA16DET
1985 Nissan Fairlady Z 300ZX Z31 2+2
BeyondBiscuits2 is offline   Reply With Quote
Old Feb 1st, 2013, 09:52 PM   #14 (permalink)
I finally came up with a solution and I did a complete write-up!!! Wilburk I used your picture in one section.
Here's the link so enjoy!!!
http://www.nissanforums.com/ga16de-1...ver-spark.html
Old Feb 1st, 2013, 11:09 PM   #15 (permalink)
wilburk's Avatar
Nice! I'm glad my picture could help. Looks like you got creative and it worked! Crushed it. Boom.
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
