Old Feb 23rd, 2003, 08:05 PM   #1 (permalink)
OmarMiPi
Send a message via AIM to OmarMiPi
Which bolts move PS pump?
I am replacing my belts (still) and I am having some trouble finding the bolts that loosen the power steering pump. Does the pump rotate like the alternator after I remove the bolts? Oh, and which direction do the bolts face? Thanks in advance.
-Omar
OmarMiPi is offline   Reply With Quote
Old Feb 23rd, 2003, 09:23 PM   #2 (permalink)
Katana200sx
P.O.S. Truckdriver
Katana200sx's Avatar
Send a message via ICQ to Katana200sx Send a message via AIM to Katana200sx
i couldnt tell you specifically...bc i just loosened every bolt i found on the pump...the pump doesnt rotate it just goes up and down. i know there is one thats one the bottom of the pump and its head faces the dirvers side.sorry for being so vague
Katana200sx is offline   Reply With Quote
Old Feb 23rd, 2003, 11:00 PM   #3 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
Send a message via AIM to HKS20DET
loosen that ^^ bolt. that bolt is what bolts it the the bracket and allows it to pivit when loose. then loosen the lock nut on the adjuster (its to the passenger side and back from the pump) then turn the adjustment screw. you will most likely have to pry the pump forward with a wrench. not hard.
HKS20DET is offline   Reply With Quote
Old Feb 24th, 2003, 08:53 PM   #4 (permalink)
Katana200sx
P.O.S. Truckdriver
yeah what he said lol...after u do it once it will be alot easier...i had to fix my front main seal after i changed my belts and this time the belt came off just by loosening the lock nut and adjuster bolt.
Old Feb 24th, 2003, 08:56 PM   #5 (permalink)
OmarMiPi
Thanks a lot for all the help. I finally got the job done. Now, I have to find some help to replace my cylinder head!
-Omar
Old Feb 25th, 2003, 12:48 PM   #6 (permalink)
Katana200sx
P.O.S. Truckdriver
if you need a replacement head, talk to lexkyb13....ive got one for sale too, but its for a b14
