EVAP/Timing/will not start when hot
Ok, so here's the deal. I've got a 99 that I just replaced the engine with another GA16DE. I haven't set the timing yet, but the car will start just fine. When it heats up to operating temp, the car starts a rough idle and misses until it dies and will not start back up until the engine cools. I checked the codes and have an ignition code and a EVAP purge valve code. Could the timing cause a problem with the EVAP and cut the engine off at higher temps?
Any help would be great! (Also, as you can guess, I am a newb! But, fantastic webside you guys are running, huge help so far. I just couldn't find anything on this specific problem)
