» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Old Oct 31st, 2009, 08:38 PM   #1 (permalink)
ScutMonkey
After Changing Plugs and Wires, car won't start...
Ok, I have a '94 Sentra and I was having an issue where it would run rough enough to shake the car at low RPMs in each gear, but smooth out at higher RPMs, so I decided to replace the plugs and wires because it hadn't been done in a while.
But I didn't write down the wire order. I looked it up online and everything says 1342 so I hooked them up as I thought it would be, but now the car won't start. The starter turns over just fine, but it never catches and cranks up, so I want to verify that "1" on the distributor is really 1. If I'm looking at the engine I'm assuming it's 1,2,3,4 from left to right. The "x" is a blanked out peg that looks like the other plug ins
---x---
1--I--2
3-----4
The "I" in the middle is the ignition plug in the center of the distributor.
ScutMonkey is offline   Reply With Quote
Old Oct 31st, 2009, 08:49 PM   #2 (permalink)
BigRed163T
I have a 97, so yours she be almost the same. If you are standing beside the driver's side fender looking straight at the distributor the #1 tower is at the 6 o'clock position. Then moving counter-clockwise you have 3, 4, 2 then back to #1. As you look straight at the distributor the rotor rotates counter-clockwise.
Hope this helps.
BigRed163T is offline   Reply With Quote
Old Nov 1st, 2009, 01:30 AM   #3 (permalink)
pulsar86
Nissan Fanatic
pulsar86's Avatar
Number one cylinder will be at pulley end of engine. If you rotate the engine to line up the tdc timing mark the rotor will point to number one post on the distributor, the next in rotation will be the next cylinder in the firing order in your case 3 then 4 then 2 and back to one if your info is correct, your owners manual should tell you the correct firing order. It is a good idea to replace plug leads one at a time and not pull them off all at once when fitting a full set.
Aussie 1986 PULSAR 23 years one owner, still going strong!
pulsar86 is offline   Reply With Quote
Old Nov 1st, 2009, 12:40 PM   #4 (permalink)
ScutMonkey
Yeah, I know better. I just wasn't thinking.
Anyway, I'm going to give it another go today. We'll see what happens.
Old Nov 1st, 2009, 08:29 PM   #5 (permalink)
ScutMonkey
Nope, it still won't start. Now I'm worried I damaged something when I tried to start it in the wrong order.
Any other suggestions?
Old Nov 1st, 2009, 08:41 PM   #6 (permalink)
Faja
Nissan Fanatic
Did you pull back out the plugs and checked them? Also maybe you knocked something else loose while changing the distributor - like a vacuum line or maybe fuel pump relay connector or any such thing??
Faja is offline   Reply With Quote
Old Nov 2nd, 2009, 01:00 AM   #7 (permalink)
pulsar86
Nissan Fanatic
pulsar86's Avatar
Thumbs up
Crossing the leads shouldn't have done harm. Have someone crank the car and with a pair of pliers hold the coil lead and earth the end to the block to check the coil has spark, also check inside of distributor cap to make sure the contact button from the coil lead to the rotor hasn't gone missing I have seen it happen.
Old Nov 3rd, 2009, 03:10 PM   #8 (permalink)
Jopet
Send a message via Yahoo to Jopet
you have a 94 sentra. External ignition coil, are all the wires plugged back in? on the 95-99 the ignition module is internal, so there are only 4 wires connnected to the distributor. There should be 5 wires on your engine. And yes, you might have pulle something out while changing the wires. Check if you have a spark, check if you have fuel.
Jopet is offline   Reply With Quote
