Old Feb 11th, 2003, 08:37 PM   #1 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
Send a message via AIM to HKS20DET
wierd idle problem???
another idle problem. i couldnt find anything on this problem...
when im driving (any speed) and i push in the clutch my car will idle at 1600+/- 100. only when i come to a complete stop (and i mean not even 1mph) will it go down to 900 to 1000rpm. what could this be???
HKS20DET is offline   Reply With Quote
Old Feb 11th, 2003, 11:12 PM   #2 (permalink)
MontyCrabApple
Nissan Fanatic
My friend is having a similar problem with his '93 NX. The problem started when he put fuel injector cleaner in tank. A few days later his car was idling eraticly. When we were cruising and than came to a stop, the car would bog out and die. Some shade tree mechanic checked out the car. He suggested the problem was originating from the Air Intake Idle valve which is the small electrical unit mounted on the passenger side of the intake manifold. That wasn't the problem. I think the fuel injector cleaner loosened up some gunk in the gas tank and than clogged up his fuel system. So, did you use any fuel injector cleaner or any other chemicals befor the problem started? I say go get your fuel system checked. It is probably the culprit.
MontyCrabApple is offline   Reply With Quote
Old Feb 12th, 2003, 05:39 PM   #3 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
yeah ive used some cleaner. a couple times actually. damn... you think me having a 2.5" way to large exhaust would make it do that?
Old Feb 13th, 2003, 12:09 AM   #4 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
sounds like the IAC valve or idle air control solenoid to me.
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Feb 13th, 2003, 03:13 PM   #5 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
the whaaaaa.....? where would i look for these things?
