New Oil in both.
if you spin the motor on the starter till the oil light goes out with the ignition off i would think that would be enough. That what i have done with rebuilt engines in the past.
Added complication is the fuel pump, injectors. I would want those off when doing this.
then Turn everything on and fire it up.
The trans should be ok as it doesn't have an oil pump like some have.
Check the distributer cap, rotor for water, dirt etc.
Good luck.
1997 Sentra GXE .... SOLD
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
