Sentra 97 Water Pump? - Nissan Forum
post #1 of 2 Old Jun 16th, 2008, 12:31 AM Thread Starter
Hi there
I have a "Nissan Sentra GXE 1997 (Auto Trans)"
I started having this weird noise from the engine
similar to this video here "Bad Water Pump vs Good Water Pump"
And my dad checked it out said it also was a Bad Water Pump. I also have a little leak on the side like under the belts. I thought it was a Oil Leak at 1st but now i think it's a Coolant Leak.
Now that i believe its a bad water pump.
Should I get only a new Water Pump? or should I get some other things..
Also I hear that when you try to replace it you should go ahead and replace the other stuff, like the belts or something.
I was looking at these Water Pumps here.
Water Pump's
Universal - Proform Water Pump
So what do you guys think? Really I was going to just go down to the local AutoZone or something but either way just wanted to know if I only need a Water Pump.
Also if anyone has reinstalled a water pump could you please provide some instructions for reinstalling on a "Nissan Sentra GXE 1997" I actually already kinda know where it is. just want some Instructions if possible.
Jetwave is offline
post #2 of 2 Old Jun 16th, 2008, 11:39 AM
Nissan Addict
greenbean699's Avatar
go get a new pump, thermostat and a tube of import gray sealant.
'08 Sentra 2.0 S--chrome billet grille
'92 xe---HS CAI, ES Motor Mounts, SE-R swaybars w/poly bushings
'92 240sx- RB25DET swap with Silvia Front Conversion
'94 HardBody- stock for now....
I've always said - beware of the guy with primer on his car!
greenbean699 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
