You really should fill upp the radiator from the cap! If your car doesn't give warm air into cockpit anymore then you don't have much coolant left (just for information). If you haven't previously followed radiator fluid level then now is the time because there might be some reason why fluids are disappearing from the radiator. If this happens in the future too then post up here and we'll think together what migth cause it.
- No-Pain -
Nissan Almera (equal to Sentra) 1997 1.6 litres
Mods so far:
-Added disc brakes to rear
-All corners have got new springs and shock absorbers (monroe reflex)
-custom made 4-->1 exhaust manifold with 2" piping -Some cool kameleont painting
-Head work done. Porting, some valve job (lightening, cleaning and polishing). Intake- and exaustports on the head totally re-designed and grinded.
-Some gauges: oil temp, oil pressure, fuel pressure, meter, lambda and external rev. meter with change ligth
-Free flow air-filter (calculated intake pipe lenght) with CAI.
-Lightened battery, moved to back
- No-pain -
