Pinging or Knocking engine sounds during acceleration or uphill - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Jun 9th, 2008, 09:05 PM   #1 (permalink)
Hi. My GA16DE 92 makes this Knocking noise once it reaches normal working temperature. I've check the timing and it is ok 10º. I'm using 90 octanes fuel and even when i use 95 octanes fuel, it starts to knock after running for 30 min. When the engine is cold o has not reach the normal operation temperature, it doesn't make any knocking noise. Any idea what the problem could be please?
pepe_moro is offline   Reply With Quote
Old Jun 10th, 2008, 12:53 AM   #2 (permalink)
Nissan Fanatic
kizer24's Avatar
Well im new to these engines and cars, but I would say the ECU would prob go into limp mode for any of the major sensors went out. So I would say check the fuel filter, fuel pump, and fuel pressure regulator. If you are running lean those would be a place to start. You should look at the O2 sensor at the same time. I'm not sure how to test them but I believe there is a way. Oh and please anyone else with ideas please help out or add anything I missed.
kizer24 is offline   Reply With Quote
Old Jun 10th, 2008, 08:32 AM   #3 (permalink)
I Live Here
IanH's Avatar
this could be a mechanical problem, maybe a rod bearing. Listen with a long screw driver and open the throttle in short burst. if the knocking is in area of one cylinder and doesn't do this cold only hot when Oil is thin then this is a possibility.
Try adding an octane booster, this would rule out a the normal engine pre-ignition.
Sorry this is all I can think of to add to the above suggestions. Good Luck......
2003 Pathfinder from 2004 SE 4WD
1997 SER 5sp Manual from new Rear Ended 2009 !!
Gone to the Knacker yard...
New ride 3.0 manual RWD not a Nissan !!!
1997 Sentra GXE from new .... Sold 2008
2001 Sunny N16 RHD from new (N16 Nissan Bluebird Sylphy) Sold
IanH is offline   Reply With Quote
Old Jun 11th, 2008, 12:43 AM   #4 (permalink)
Nissan Fanatic
I have this problem since day one I owned my sentra.Last for 4 years and put almost 100k miles.Kind of annoying but works ok.All kinds of tune up does not solve the problem.
But now it is getting worse...Time to get another engine...
joeli16 is offline   Reply With Quote
Old Jun 11th, 2008, 07:16 AM   #5 (permalink)
Sup Mod keeping the peace
rogoman's Avatar
Several possibilities:
- Make sure the oil level is at the full mark.
- If the noise has a metallic sound to it, then it could be a worn rod/main bearing.
- The oil pressure may be abnormally low. Check it by using a temporary pressure gauge.
KA-T for life, yo!
Old Jun 11th, 2008, 08:29 AM   #6 (permalink)
I Live Here
IanH's Avatar
Good suggestions.
Well 100K miles, I don't think its a rod bearing!!
Are you hearing the valve lash clatter ?
GA's don't have hydraulic lifters, shim adjustment.
I would check the valve clearances next.
It should be easy to rule out detonation with octane booster.
Old Jun 13th, 2008, 12:41 AM   #7 (permalink)
Nissan Fanatic
It happens usually if I push the engine harder or it's uphill.Does not have any pinging when it's idling.
Yes actually first I thought it was spark knock,so maybe the timing was retarded.Set the timing right but still got this noise.I always run with full engine oil.
I start to suspect either timing chain guides/tensioners go bad or worn bearings.But anyone of this things will just make me change the engine.This engine is like 230k miles and just not worth putting more money in it unless I have the money to rebuild the whole thing.I have done all kinds of tune up but the noise is still there.Worn engine is the only possibilty I can think of.
The pinging gets worse when it's hot,especially in summer.
Old Jun 13th, 2008, 08:31 AM   #8 (permalink)
rogoman's Avatar
Probably carbon buildup in the combustion chambers is causing pre-ignition.
KA-T for life, yo!
Old Jun 14th, 2008, 12:50 AM   #9 (permalink)
No-Pain's Avatar
Send a message via MSN to No-Pain
Complete fuel system cleaner might help because it's supposed to clean fuel system and also vents and combustion chamber. In finland we have for repair shops professional use liquid called forte fuel system cleaner. It's quite like the best available on the market. Try that and hopefully it removes some carbon buildups. Assumpting that knocking is because pre-detonation.
- No-Pain -
Nissan Almera (equal to Sentra) 1997 1.6 litres
Mods so far:
-Added disc brakes to rear
-All corners have got new springs and shock absorbers (monroe reflex)
-custom made 4-->1 exhaust manifold with 2" piping -Some cool kameleont painting
-Head work done. Porting, some valve job (lightening, cleaning and polishing). Intake- and exaustports on the head totally re-designed and grinded.
-Some gauges: oil temp, oil pressure, fuel pressure, meter, lambda and external rev. meter with change ligth
-Free flow air-filter (calculated intake pipe lenght) with CAI.
-Lightened battery, moved to back
- No-pain -
No-Pain is offline   Reply With Quote
Old Sep 16th, 2008, 05:29 PM   #10 (permalink)
Originally Posted by IanH View Post
Good suggestions.
Hi, I apologize for coming in to this thread so late. I am having almost the same situation as the person how started this thread with a 1994 Sentra GA16DE. The difference may be that I am in Panama and we always have hot weather. I was wondering if you could illustrate me on the Items you mention e.g. Valve lash clatter, Shim adjustment, etc.
Please help in anyway possible.
RasJ is offline   Reply With Quote
Old Sep 16th, 2008, 11:37 PM   #11 (permalink)
I Live Here
IanH's Avatar
download the Factory service manual its free at phatg20.net
I think the engine above with 230K miles needs new chains and at that mileage maybe not worth it as low mileage replacements are relatively in-expensive.
Check your timing and try if its still making noise add Octane booster. it it doesn't stop its not detonation. We have knocksensors anyway, so i don't think the engine will knock due to pre-ignition.
Your first suspect should be the upper timing chain tensioner and guides if you are above 120K miles ( not Km) they seem to go bad, your mileage will vary!!
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
