Old May 12th, 2008, 11:32 PM   #1 (permalink)
BeyondBiscuits2
300+ posts
BeyondBiscuits2's Avatar
Send a message via AIM to BeyondBiscuits2
370cc or 259cc?
I have finally acquisitioned everything I need to "properly" turbo my GA16DE in my B12 Sentra. Here is everything I currently have:
S13 SR20DET Garrett T25 turbocharger
S13 SR20DET side-mount intercooler
spare GA16DE fuel rail
adjustable fuel pressure regulator
Nissan Maxima N60 MAF sensor
Integrated Engineering Cometic T25 gasket
TSI GA16DE turbo manifold
S13 KA24DE fuel pump
Apex'i S-AFC 2
wideband (used but functional)
sequential blow-off valve
four 259cc fuel injectors (KA24DE)
four 370cc fuel injectors (SR20DE)
spare oil pan (welded drain for oil)
Here's my question: should I initially tune my GA16DE(T) with the 259cc injectors and KA24DE fuel pump, or should I make the leap to the 370cc injectors and get a Walbro 255 lph pump? Both sets of injectors I got from a friend in good working order, and I know the KA24DE fuel pump works well (pulled it from a recently wrecked S13). I only want around 8 lbs of boost (I don't think my poor B12 can handle much more), and is it worth all the trouble of buying a Walbro pump and using the 370s?
NISSAN:shift_
BeyondBiscuits2 is offline   Reply With Quote
Old May 13th, 2008, 10:22 AM   #2 (permalink)
alfsentra
In my opinion... Walbro Fuel Pump and DET (370cc) injectors. With good tuning you can run 10-12 psi. This FPR is from ebay? My friends have bad experiences with this regulators. I like Nismo FPR but for low budget I have this:
eBay Motors: BLOX ADJUSTABLE FUEL PRESSURE REGULATOR POLISHED CIVIC (item 140232638308 end time May-19-08 19:31:07 PDT)
No Tuning = No Life
alfsentra is offline   Reply With Quote
Old May 13th, 2008, 10:42 AM   #3 (permalink)
BeyondBiscuits2
300+ posts
Yeah, eBay special. I am actually most likely not going to use it; I'll keep my stock Nissan fpr at 3 bar of pressure. I have an S-AFC 2, also, should tuning should not be difficult.
The problem with running higher boost levels is my B12 Sentra most likely won't hold together very well. I don't want to crap out CV axles or other components because I am running too much boost. Obviously, a boosted car takes much more daily abuse than an N/A one.
NISSAN:shift_
Old May 13th, 2008, 11:37 AM   #4 (permalink)
2dr_Sentra
Mr. Ghetto Rig
2dr_Sentra's Avatar
Send a message via AIM to 2dr_Sentra
i would just go 370cc, you can pick them up for about 100 shipped.
1997 Nissan 200SX SE-R -Turbo Lowport, S4 cams, 3inch turbo back exhaust
2007 Versa SL 6 speed
1991 Nissan Sentra XE w/ 1.6L - sold :(
2dr_Sentra is offline   Reply With Quote
Old May 14th, 2008, 07:26 PM   #5 (permalink)
BeyondBiscuits2
300+ posts
I've decided to just run the 370cc injectors I have. If need be, I can just tune everything down for low boost. I also just purchased a Walbro 255 lph fuel pump, so I should have no problem there. Correct me if I am wrong, but doesn't the SR20DET T25 have it's wastegate set at 8 lbs of boost? If so, I imagine I'll just run stock boost and leave it at that unless I start feeling adventurous.
Does anyone know the next step-up from 370cc injectors that are side-feed Nissan? I know the S15 SR20DET has larger injectors; how much spray are they and how easy are they to find?
NISSAN:shift_
