Old May 6th, 2008, 08:26 PM   #1 (permalink)
wwolf771177
Send a message via AIM to wwolf771177
how much boost...
can the ga16 take.I plan on daily driving on 10lbs what do you guys think
wwolf771177 is offline   Reply With Quote
Old May 9th, 2008, 12:49 PM   #2 (permalink)
turbo200sx007
Send a message via AIM to turbo200sx007 Send a message via Yahoo to turbo200sx007
sounds fine what engine management? i was runnin 10 pounds for about 2 months on emange ultimate, just turned it up to 15lbs .. is it a ga16de
turbo200sx007 is offline   Reply With Quote
Old May 9th, 2008, 07:09 PM   #3 (permalink)
wwolf771177
yeah i have a rebuilt ga16de. no emanage im getting a JWT ecu 370injectors and sr20 maf
Old May 9th, 2008, 09:42 PM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
SR MAF is not enough IMHO. Also you cannot ask how much boost the motor can hold. 10 PSI on a T25 makes much less power than 10 PSI on a big T3/T4 turbo. The question should be how much power can the engine hold and then tune for that power level.
250WHP has proven to be plenty reliable with the right tune.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old May 10th, 2008, 07:43 AM   #5 (permalink)
wwolf771177
I spoke to a JWT tech and he told me they only have a program for 370injectors and sr20 maf ( i think hes bullshitting me ) i have a rb25det maf that i would have loved to use...
Old May 10th, 2008, 11:22 AM   #6 (permalink)
wes
Wise Cracker
wes's Avatar
That is wrong. I have personally had two different JWT turbo programs on my ecu.
370's and S14 240sc MAF (good to approx. 250 whp)
MSD 59 lb injectors and Cobra MAF (good to approx. 350 whp)
I would use one of these setups as they have been used by different people and are known to work.
JWT
www.notnser.com
Old May 10th, 2008, 04:27 PM   #7 (permalink)
wwolf771177
the 240sx maf you had was it from the ka24de engine? im about to just listen to the tech and get a sr20 maf with 370's i mean he should klnow what hes talking about. also what color label does the maf from the 240 have?
Old May 10th, 2008, 08:46 PM   #8 (permalink)
wes
Wise Cracker
wes's Avatar
All 240's had the KA24, the MAF JWT tuned for is from the S14 chassis 240 only!
I am 100% certain in what programs they have done in the past, my car is sponsored by JWT and I have worked with Clark personally on one of the programs.
JWT
www.notnser.com
Old May 10th, 2008, 09:38 PM   #9 (permalink)
wwolf771177
what do you suggest i do? should i call JWT and speak to another tech? or should i just go with the sr20 maf? i dunno...
Old May 11th, 2008, 12:34 AM   #10 (permalink)
streetprojects01
streetprojects01's Avatar
Send a message via AIM to streetprojects01
I also had a tech tell me to add a 1995-98 240SX MAF sensor and use the fuel map for a 370's...
I would listen to him
streetprojects01 is offline   Reply With Quote
Old May 11th, 2008, 09:24 AM   #11 (permalink)
wwolf771177
listen to who the tech? the tech told me to use 370's with a sr20 MAF, eveyon1 else uses a 240maf
Old May 13th, 2008, 09:35 PM   #12 (permalink)
streetprojects01
yeah use the 240maf i dont know why he told you use the sr20maf, the 370's should work fine with that combination. Im going to be running shortly with the same combinations on my motor
Old May 22nd, 2008, 11:16 PM   #13 (permalink)
streetprojects01
I had a question, couple of my buddies suggested in getting a MAF from an 95+ Altima uses the same MAF since it uses the same motor: K24DE would that work????
I know that the 240MAF are hard to come fine at a reasonable price
Old May 23rd, 2008, 08:12 AM   #14 (permalink)
wes
Wise Cracker
wes's Avatar
Good idea... I would have adealer or someone with access to FAST cross reference the two MAFS to verify they are the same part #. The beauty of the 240 MAF is that it uses the same plug as the B14 GA 16 so it is plug and play.
JWT
www.notnser.com
Old May 24th, 2008, 04:46 PM   #15 (permalink)
wwolf771177
where can i find a s14 maf for cheap
