Old Apr 27th, 2008, 03:39 PM   #1 (permalink)
TJ 200SX SE
TJ 200SX SE's Avatar
SR20 parts that fit GA16?
I have been curious if anyone knows what parts from an SR20 200sx are compatable with my GA16 200sx...
.along with the motor simularities....
is there anything from the SER 200sx body that i can use....things like a rear sway bar, ect...
TJ 200SX SE is offline   Reply With Quote
Old Apr 27th, 2008, 05:54 PM   #2 (permalink)
nissannx
Lots of body and brake parts are interchangeable.
The SR20 motor and drivetrain are different and not interchangeable.
Have fun.
1992 NX1600 Original Owner 191 000 km.
1991 NX2000 hardtop Second Owner 162 000 km.
2007 Altima 2.5 S
2008 Versa
nissannx is offline   Reply With Quote
Old Apr 28th, 2008, 03:48 PM   #3 (permalink)
BeyondBiscuits2
300+ posts
BeyondBiscuits2's Avatar
Send a message via AIM to BeyondBiscuits2
Spark plugs and oil filter... that's about it in terms of engine components.
NISSAN:shift_
BeyondBiscuits2 is online now   Reply With Quote
Old Apr 28th, 2008, 09:09 PM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Oil filters are different between the B14 GA and SR20....
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Apr 30th, 2008, 06:51 AM   #5 (permalink)
clifton062
isnt te exhuast interchangable eh?
clifton062 is offline   Reply With Quote
Old Apr 30th, 2008, 01:51 PM   #6 (permalink)
BeyondBiscuits2
300+ posts
Most likely from cat-back.
NISSAN:shift_
Old Apr 30th, 2008, 09:32 PM   #7 (permalink)
TJ 200SX SE
how about suspension stuff?....and is there a rear sway bar on the SER that would directly fit the SE B14
And thank for all the helpful info...
Old May 1st, 2008, 02:49 PM   #8 (permalink)
92nx
Get the Suspension Techniques anti sway bars. Keeps my nx1600 flat and stable in corners
Friends don't let friends drive stock.
92nx is offline   Reply With Quote
Old May 1st, 2008, 08:58 PM   #9 (permalink)
wes
Wise Cracker
wes's Avatar
The rear sway bar on the B14 chassis is part of the rear beam itself. The 200se se and se-r share the same rear beam. AFAIK only the base model is different. An aftermarket rear sway bar is the only way to go. The ST bars are good but the Still and Progress rear bars are better products that offer easier installation as well as adjustability.
The Front sway bars on the se and se-r are the same as well. The main difference between the two cars is the drivetrain and brakes.
JWT
www.notnser.com
Old May 1st, 2008, 10:13 PM   #10 (permalink)
TJ 200SX SE
Hey can i ask u how much u paid for that and did you get a front one with it?
Old May 1st, 2008, 11:05 PM   #11 (permalink)
92nx
It was just under 400 (canadian) for the set. Front is 30mm and rear is 19mm. I really like the feel and control it gives the car. i may have chosen an adjustable set as wes mentioned but when the amount of aftermarket parts available for your car are next to none you gotta make due with what you can find.
Old May 5th, 2008, 01:38 PM   #12 (permalink)
TJ 200SX SE
can i take the brake components from the ser and put them on my se with little or no difficulty?
I think i'm going to go with the stillen rear sway bar..... cuz of the ajustability
Old May 6th, 2008, 09:16 AM   #13 (permalink)
IanH
Post Freak
IanH's Avatar
Fronts yes, rear Disk from Drums you need the beam axle or the fast brakes adapter plates.
(and E Brake cables)
What year is your 200SX. I believe 98 and 99 have the SE-R front brakes anyway.
1997 Sentra GXE w/195/50 15's and AD22VF, Tach, Halo's, Front seal, Rear SER Disc Brakes Soon to be sold
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
Old May 7th, 2008, 05:16 PM   #14 (permalink)
TJ 200SX SE
its a 95 so i would need to get the adapter plates
Old May 7th, 2008, 10:17 PM   #15 (permalink)
wes
Wise Cracker
wes's Avatar
What adapter plates, for the rear brake conversion? If so then there are two ways to do it, fastbrakes or swap the rear beam.
For the front skip the SE-R brakes and go straight to the NX2000 upgrade.
JWT
www.notnser.com
