Water Pump - Nissan Forum
post #1 of 16 Old Apr 14th, 2008, 11:54 AM Thread Starter
Question Water Pump
How do I replace the water pump on a Nissan 200sx with a 1.6 engine?
louiethelizard is offline
post #2 of 16 Old Apr 14th, 2008, 12:23 PM
I Live Here
IanH's Avatar
Download the Nissan Service manual from phatg20.net
Its free !!!
then see instructions (LC-20 on the 1996 FSM)
Good luck....
2003 Pathfinder from 2004 SE 4WD
1997 SER 5sp Manual from new Rear Ended 2009 !!
Gone to the Knacker yard...
New ride 3.0 manual RWD not a Nissan !!! Gone 2016 from Hail damage.
1997 Sentra GXE from new .... Sold 2008
2001 Sunny N16 RHD from new (N16 Nissan Bluebird Sylphy) Sold
IanH is offline
post #3 of 16 Old Aug 26th, 2008, 06:59 PM
Question Help on replacing water pump (GA16DE)
I just downloaded the Service Manual from phatg20.net as suggested on the previous post...
The following steps are listed:
1.Drain coolant from radiator and cylinder block
2.Remove cylinder head front mounting bracket.
3.Loosen water pump pulley bolts.
4.Remove drive belts for power steering pump.
5.Remove water pump pulley
6.Remove coolant hoses from water inlet and thermostat housing.
7.Remove water pump bolts.
8.Remove water pump with thermostat housing.
The steps listed are the same on the Haynes Manual.
With these steps, I am still unable to get to the water pump. There is very little room to move around in.
Although the Haynes Manual does not instruct to do so, there is a photo of the water pump being unbolted. In this photo, it shows that the coolant reservoir tank, power steering tank (or container), and the fuse box removed. The photo also does not show the A/C lines.
I moved the coolant reservoir tank, fuse box, and the power steering fluid container out of the way so I can get to the water pump. I did not touch the a/c lines because it might release some pressure. After all this, I am still unable to get to the water pump.
Has anyone successfully removed and replace the water pump? Please let me know what additional steps I need to take. Please help..
95_200SX is offline
post #4 of 16 Old Aug 26th, 2008, 08:13 PM
800+ posts
BeyondBiscuits2's Avatar
Send a message via MSN to BeyondBiscuits2 Send a message via Yahoo to BeyondBiscuits2
The water pump is in a very precarious place. What I did was place a block of wood between a jack and the crank pulley, unbolted the passenger side engine mount, and lightly jacked up the engine until the water pump cleared the frame rail. It makes removal and replacement much easier... but make sure to use the wood otherwise you could damage the crank pulley or crankshaft itself. Also use some light wood, so the wood has some give in it.
The Sentra Channel:
Subscribe Today!
1990 Nissan Sentra B12 GA16DET
1985 Nissan Fairlady Z 300ZX Z31 2+2
2002 Acura RSX Type S
BeyondBiscuits2 is offline
post #5 of 16 Old Aug 26th, 2008, 11:44 PM
Nissan Addict
greenbean699's Avatar
i've done it like that and i have also lowered the engine and replaced the water pump from the passenger wheel well.
'08 Sentra 2.0 S--chrome billet grille
'92 xe---HS CAI, ES Motor Mounts, SE-R swaybars w/poly bushings
'92 240sx- RB25DET swap with Silvia Front Conversion
'94 HardBody- stock for now....
I've always said - beware of the guy with primer on his car!
greenbean699 is offline
post #6 of 16 Old Aug 27th, 2008, 12:03 AM
Send a message via AIM to 94 Sentra-XE
i did mine the same way, thats your best bet
1993 Nissan NX2000- PARTING OUT. PM OFFERS, WILL NOT BE TURNED DOWN
1994 Nissan Sentra XE-R- sold for 2x total costs
1995 240sx- winter project almost completed
94 Sentra-XE is offline
post #7 of 16 Old Aug 30th, 2008, 01:50 AM
I caught how to lift the engine but how does one lower the engine?
Thanks
travelwizard is offline
post #8 of 16 Old Sep 2nd, 2008, 08:19 AM
95_200SX,
I had to replace mine this weekend and did same as you but I removed the thermostat housing and disconnected the AC lines. Without raising or lowering the engine I was able to get the WP out. I figured the freon was cheaper than my time and effort. Bad news is that I got all back together to discover that I had cracked the water outlet when tightening the lower bolt #%&@! At least I can get to it without too much trouble.
cmccrkn is offline
post #9 of 16 Old Sep 2nd, 2008, 10:30 AM
Block Rockin Beats
fleck's Avatar
Thanks
my only guess is support the engine with a jack or tower and then jack up the car, after undoing the mount of course.
Done: Intake, Super-lightened (gutted interior), tight throttle, open exhaust, seventeen inchers. 8sec 0-60! WIP...
fleck is offline
post #10 of 16 Old Sep 2nd, 2008, 01:41 PM
Thanks for the input.
Since I bought the car w/the A/C inoperable I might just take a look at that disconnecting method.
Funny thing was I'd noticed the small radiator fluid leakage for months but it showed up dripping from bottom of A/C pump and could not trace where it originated from, just assuming it was water pump. Took 3 trips to mechanics to verify. Other 2 mechanics after extensive searching just gave up and said "don't know" and "keep an eye on it."
post #11 of 16 Old Sep 18th, 2008, 11:34 PM
Smile Water Pump Replacement Done
Thanks to everyone's suggestions, I was finally able to replace the water pump...
As suggested in this post, I unbolted the engine mount and raised the engine. This gave enough clearance to access the water pump. I also had to remove the power steering container and move the fuse box to the side. This gave enough clearance to remove the water pump. It was still a challenge trying to remove the thermostat housing and the thermostat because the A/C lines got in the way, but I managed to work around it.
Since I was doing the work from above the engine, removing the clamps from the thermostat hoses was slightly difficult. This is because the screws on the clamps were facing from the bottom. But since I was replacing the hoses also, I just ended up cutting the hoses and removing them with some pliers.
I realized later that the hoses can be reached from the bottom. I could have unscrewed the thermostat hose clamps from the bottom of the car. They are located in an area just above the oil filter.
201,000 miles and counting....
Thanks again for everyone's help....
95_200SX is offline
post #12 of 16 Old Sep 19th, 2008, 12:28 PM
Also, water pump replaced, not without some...
Also was able to loosen engine mounts and raise the engine on my '93 Sentra XE. Water pump was replaced but took this amateur about seven hours at a leisurely pace.
At one point the 75 yr old woman neighbor came out and began to tell me I was going about it all wrong and didn't have to go to such extreme measures as loosening engine mounts. She was probably getting bothered at my cursing and yelling at tight bolts and cut fingers. Hour later she came out again and actually told me she'd called HER mechanic and HE said I didn't have to loosen engine bolts, etc., etc. At that point wanted to loosen her bolts.
post #13 of 16 Old May 31st, 2009, 02:52 PM
is anyone a profesional mechanic and knows the correct way to do this? maybe there is a better way of pulling it out other than jacking up the engine. and if you take out only the passenger engine mount and jack the engine up wouldn't that put stress on the other parts of the engine?
joenathan89 is offline
post #14 of 16 Old Jun 5th, 2009, 03:52 PM
freakish poster
Centurion's Avatar
^It really isn't a big deal to raise the engine. I rasied it by the oil pan (with a block of wood for "padding"). When we say raise the engine, it's only a couple of inches or so, so nothing gets really stressed.
1993 Sentra XE auto (original owner)
2005 NISMO Frontier
Centurion is offline
post #15 of 16 Old Jun 6th, 2009, 01:50 AM
oh ok cool. so is the water pump a big job? or can i knock it out in an afternoon?
im just an amateur at this stuff but i've done a axle cv joint replacement. how does this compare in difficulty?
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
