Old Mar 8th, 2008, 01:24 AM   #1 (permalink)
ogco2006
ogco2006's Avatar
Exclamation tranmision mount for 1991 auto Sentra
ive located the mount but i am not sure on how to really get it out and swap in the new one does any one know how to do it and can give me some ideas or pictures would help... i have accest to lifts and power tools that is not a problem getting it out is what i still dont know how to do since the bolts are in hard to reach locations
Drive Fast Swerve Hard!!!
ogco2006 is offline   Reply With Quote
Old Mar 8th, 2008, 07:41 AM   #2 (permalink)
mrgoose
If your 91 sentra is the same as my 93, then you probably need to remove the battery and the battery pan first to get at the transmission mount. Then you need to support the transmission from underneath with a jack and a piece of wood to take the weight off the mount. This can be a little tricky since you want to take the weight off the mount, but not stress it in an upward or other direction. Then you should be able to unbolt the old mount. Installing the new mount can be a little tricky because the transmission might not be in the perfect position. You can use a big crowbar to move the transmission around a bit to get it to line up with the bolt hole on the chassis so that you can install the mount.
mrgoose is offline   Reply With Quote
Old Mar 8th, 2008, 10:43 AM   #3 (permalink)
greenbean699
Nissan Addict
greenbean699's Avatar
there are 2 transmission mounts, one under the battery and one under the car on the cross member. if its the one on the cross member, then you have to remove the cross member to replace it, then reinstall. if its the one under the battery, its simple.
'92 xe---family car
'89 w/ga16de---work car
'87 rare sentra h/b w/ca18de---honda killer
'89 sport coupe---future swap.....
Originally Posted by Campground Man View Post
I've always said - beware of the guy with primer on his car!
greenbean699 is offline   Reply With Quote
Old Mar 8th, 2008, 05:59 PM   #4 (permalink)
ogco2006
ogco2006's Avatar
im talking about the one under the car that one is cracked and and ill give the one under the battery a look all the mounts ive seen from above on my engine look okay still its that bottom one that i need help with so just lift sligly and pry it out should do able to me wont be the first time i take out a mount for a car had to do a 91 accord all 3 mounts with a homie Thanks
Old Mar 8th, 2008, 11:12 PM   #5 (permalink)
joeli16
Nissan Fanatic
As I remember the mount is bolted on the cross member.If you wanna change that mount,you have to take the cross member out first.I would put a jack underneath the transmission also.
joeli16 is offline   Reply With Quote
Old Mar 9th, 2008, 05:38 AM   #6 (permalink)
ogco2006
ogco2006's Avatar
so its best to do it on the floor and not on a car lift...
Old Mar 10th, 2008, 09:13 AM   #7 (permalink)
schatman
Hi,
Anyone know if the cross member must be removed for the standard tranny?
Thanks
Shawn
schatman is offline   Reply With Quote
