Oil Pan Liquid Gasket - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Jan 31st, 2003, 08:13 PM   #1 (permalink)
1.6 Turbo Power
Send a message via AIM to AznVirus
what type (color) of sealant do i use for the lower oil pan gasket? is it neccessary to raise the engine? according to the FSM i am supposed to raise the engine and support the transmission, but not sure if its neccessary. thanks.
Deric
1.6 - The Underdog
GA16DE-T Owners Club!
153 HP & 152 TQ
AznVirus is offline   Reply With Quote
Old Jan 31st, 2003, 09:01 PM   #2 (permalink)
If I remember correctly you need to use the gray sealant. You don't need to raise the engine but it does help if you remove the exhaust downpipe. The front crossmember is a tight fit, but it can be done.
Michael DeLoach is offline   Reply With Quote
Old Feb 1st, 2003, 12:40 AM   #3 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Post
Use any liquid gasket suitable for use with engine oil.
The oil pan can be removed and installed WITH the crossmember and tranny. in place. It just takes a 1/4" drive swivel adapter on your socket to reach the two nuts that are partially covered by the tranny casing.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Feb 3rd, 2003, 11:15 AM   #4 (permalink)
Nissan Fanatic
Wes is right, just make sure the sealant is oil resistant and high temp.
The best stuff on the market is the "Right Stuff for Imports". It is made by Permatex, comes in a grey can that looks like a can of Cheeze Whiz. It works great and makes applying a nice continuous beasd very easy.
1991 Sentra SE - Auto to Manual swap, 15" Rota Subzero's, 205/50 Kuhmo 712's, Tsuru headlight conversion, SE-R front and rear disc brakes, SE-R front and rear swaybars, SE-R throttle body, SE-R rear inner taillights, HS CAI and Header, H&R springs, Koni shortened struts, ES Hyperflex kit, B&M Short Shifter, Autometer gauges.
johnand is offline   Reply With Quote
Old Feb 3rd, 2003, 01:22 PM   #5 (permalink)
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
orange goo
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Feb 4th, 2003, 03:56 AM   #6 (permalink)
1.6 Turbo Power
thanks for everyones responses, got to fix my oil leak this weekend.
1.6 - The Underdog
153 HP & 152 TQ
Old Apr 12th, 2003, 06:46 AM   #7 (permalink)
Destroyer of Engines
aminidab's Avatar
My oil pan gasket is leaking as well and I plan on replacing it soon. What do I need to get to do this? Just the gasket and some sealant as mentioned in this thread?
I assume the procdeure is drain the oil, remove the oil pan(possibly the downpipe as well), get rid of the old gasket, then put on the new gasket and sealant.
Is this correct?
2008 BMW 135i
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
aminidab is offline   Reply With Quote
Old Apr 13th, 2003, 06:25 AM   #8 (permalink)
1.6 Turbo Power
As stated from the FSM.
Removal
1. Remove engine RH side cover and undercovers
2. Drain engine oil
3. Remove front exhaust tube
4. Set a suitable transmission jack under transaxle and lift engine w/ engine slinger (i did it w/o doing this, except that i supported the tranny w/ a regular jack and a piece of wood)
5. Remove center member
6. Remove front and rear engine gussets
7. Remove rear plate cover (A/T models)
8. Remove oil pan
a. Insert tool between cylinder block and oil pan
*Be careful not to damage aluminum mating face. Do not insert screwdriver, or oil pan flange will be damaged
b. Slide tool by tapping on the side of the tool with a hammer
Installation
1. Use a scraper to remove oil liquid gasket from mating face of oil pan, also remove oil liquid gasket from mating surface of cylinder block
2. Apply a continuous bead of liquid gasket to mating surface of oil pan *allow 7mm (.28 in) clearance around bolt holes
3. Be sure liquid gasket diameter is 3.5 - 4.5 mm *attaching should be done within 5 minutes after coating
4. Install oil pan (there is a certain bolt pattern for reinstalling the bolts, ill try to take a pic of it soon)
5. Install parts in reverse order of removal
Hope this helps
1.6 - The Underdog
153 HP & 152 TQ
Old Apr 13th, 2003, 01:28 PM   #9 (permalink)
aminidab's Avatar
Wow thanks AznVirus thats some good info!
Couple of questions though
Are 4 and 5 needed? Do you need to remove the center member to do this?
As for 6 what the hell is a gusset?
And finally is there only a liquid gasket needed?
2008 BMW 135i
96 Sentra GXE
Boost is addictive
265WHP/257WTQ
Old Apr 13th, 2003, 05:52 PM   #10 (permalink)
1.6 Turbo Power
Yes you need to remove the center member. There should be two gussets that attach the oil pan to the block. Gussets are just two cast iron or metal brackets. You will see them when you get under the car. And yes, there is only a liquid gasket needed. The hard part of putting it back in it getting it lined up correctly w/o smudging the liquid gasket.
1.6 - The Underdog
153 HP & 152 TQ
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
