Old Jan 14th, 2008, 12:57 PM   #1 (permalink)
bugmenot
Weird auto tranny problems! Please help.
Hello,
I posted the same thing in GA16i forum, its been 2 days and no replies. So i was hoping that somebody in section knew whats going on with my tranny, since its the same tranny on both engines (the 3-speed auto).
Here's the description:
First thing i noticed was that it wouldnt roll back (by itself) when put in reverse gear - it requires pressing gas to about 1800-2000 rpm to start moving. Forward gears work perfectly fine. In reverse however, it feels exactly like as if handbrake is engaged - it moves if you give it enough gas, and stops quickly as soon as you let off.
Second thing that i noticed is that when engine is off, neutral gear works as it should, however when engine is running, putting it in neutral causes it to engage forward gear. BUT car will only accelerate to maybe 10-15mph with the shifter in "neutral". After that pressing gas just causes the rpms to go up without any effect on acceleration. If i switch from drive to neutral on high speed, it acts exactly as it should - rpm's drop and giving it gas just causes the rpm's to jump. Both of these problems occured at the same time, and tranny was working 100% perfect before.
Any help is greatly appreciated!
Thanks
bugmenot is offline   Reply With Quote
Old Jan 14th, 2008, 06:06 PM   #2 (permalink)
greenbean699
Nissan Addict
greenbean699's Avatar
get another tranny
'92 xe---family car
'89 w/ga16de---work car
'87 rare sentra h/b w/ca18de---honda killer
'89 sport coupe---future swap.....
Originally Posted by Campground Man View Post
I've always said - beware of the guy with primer on his car!
greenbean699 is offline   Reply With Quote
'90 Stanza Auto Tranny Problem 90daughtersstanza Stanza 3 Aug 27th, 2006 10:43 PM
Tranny problems!! HELP!! Sentra88 B11/B12/KN13 82-90 chassis 3 Aug 9th, 2006 08:54 AM
95 Pathy auto tranny: Revisited? Mike in Brier Pathfinder 1 Jul 18th, 2006 02:09 AM
Tranny Problems...Need Advice Nuskool GA16DE 1.6L Engine 11 Mar 17th, 2005 09:36 AM
G20 Auto to Manual tranny swap crookiz General Discussion 1 Jul 7th, 2004 10:41 AM
