Old Jan 12th, 2008, 11:51 AM   #1 (permalink)
cirruscfi
No heat
B14 1.6 200sx
This is puzzling. The temp gauge was running cold, no heat from the vents and the radiator was cold. I changed the thermostat and flushed out the system by draining the radiator, opening both bleed valves and then closing them. I pulled the upper heater core hose, connected the garden hose and ran water toward the cylinder head. With the radiator cap on and petcock tight, coolant and then eventually water came out of the heater core from where I removed the hose. With the radiator cap off, clean water came out of the radiator. I turned the car on and the temperature gauge rose to a normal level but still no heat. Fifteen minutes later, still no heat. The upper radiator hose is warm without pressure in it. The lower radiator hose is cold. The radiator is cold.
I’m thinking it’s still the thermostat. After installing it, I’ve read that the hole on the thermostat flange should be at 12 o’clock and I doubt it is. Could that be the problem?
Thanks.
cirruscfi is offline   Reply With Quote
Old Jan 12th, 2008, 05:48 PM   #2 (permalink)
greenbean699
Nissan Addict
greenbean699's Avatar
i would turn the thermostat to the right position and try to get the air out the the line. if the heater is not working after the methods you have done before. then i would tighten all the bleeding spots and let the engine run. as it runs, take the hose clap loose a little at a time from the upper radiator hose. you will want a rag to keep from getting burned. i have done this many times, it gets easy after a few times.
'92 xe---family car
'89 w/ga16de---work car
'87 rare sentra h/b w/ca18de---honda killer
'89 sport coupe---future swap.....
Originally Posted by Campground Man View Post
I've always said - beware of the guy with primer on his car!
greenbean699 is offline   Reply With Quote
1990 300ZX Heat Problems z7z1z0 Z32 Chassis 300ZX 4 Jan 14th, 2008 03:43 PM
Lack of Heat, Gas Mileage and an Accurate Temperature Gauge No_Dice GA16DE 1.6L Engine 7 Mar 1st, 2007 10:29 AM
Heater doesnt let heat into cabin HoetheJoe Pathfinder 3 Nov 21st, 2006 09:52 PM
heat question polishhotdawg B11/B12/KN13 82-90 chassis 4 Feb 15th, 2003 07:04 PM
Heat Shield for Cone Filters sentrapower93 GA16DE 1.6L Engine 12 Oct 8th, 2002 08:53 AM
