fuel pump relay switch - Nissan Forum
post #1 of 12 Old Jan 7th, 2008, 07:03 PM Thread Starter
node0809's Avatar
Hey guys! I need help in locating the fuel pump relay switch....I looked everywhere in the engine compartment....is it possible its in the fuel tank with the fuel pump assembly? I have a 98 200sx that just quit running....cranks but wont start...change fuel filter,plugs,plug wire, rotor cap and head...i have fuel and sparks...did the fuel pump fuse trick no luck...jump/by pass the fuel pump no go....she used to run like a champ....now i'm completely lost only thing i could think of is the relay but couldnt find it..help!!!!
node0809 is offline
post #2 of 12 Old Jan 10th, 2008, 01:22 PM
P.O.S. Truckdriver
Katana200sx's Avatar
the relay is under the hood on the passenger side iirc. i never could find it when i was looking for it, but i remember when i finally did find it it was sitting it plain sight.
Need parts?
91 SE-R Partout
96 200SX SE Partout
Katana200sx is offline
post #3 of 12 Old Jan 11th, 2008, 12:59 AM
Nissan Addict
i r teh noobz's Avatar
There is a big panel next to the battery on my '93 GA16DE. There is a spot marked fuel pump, but I didn't open it to see if there was a relay or another fuse in there.
i r teh noobz is offline
post #4 of 12 Old Jan 11th, 2008, 04:55 PM Thread Starter
node0809's Avatar
iirc? could you please explain more...i know its not in the relay box nothing in there says fuel pump relay.
node0809 is offline
post #5 of 12 Old Jan 11th, 2008, 08:05 PM
Did the car just not start up one day? Or was there a series of events that eventually lead up to it not running?
mooseboy52 is offline
post #6 of 12 Old Jan 12th, 2008, 06:20 AM Thread Starter
node0809's Avatar
it just quit running while i was driving it, cost me $75 for towing and a days work trying to troubleshoot and the parts at autozone(plugs,wire,distributor cap,fuel filter,relay) parts guru there dont even know where the darn relay located at, one thing I left to mention is the car sit for maybe a month without running, i had to use it that day cause my truck is in the shop(another problem) it started fine that morning, but on my way to work it just sputter and died....like i said it will crank all day but no start...
node0809 is offline
post #7 of 12 Old Jan 12th, 2008, 07:05 AM
That sounds exactly like what happened to my car. It was cranking but not starting, i was getting spark, i changed the fuel pump and filter. I tried everything and finally took it into a shop. They found that the rotor was loose, so i was getting erratic sparking. Take a look through this and see if it helps. http://www.nissanforums.com/ga16de-1...ont-start.html
post #8 of 12 Old Jan 12th, 2008, 07:34 AM Thread Starter
node0809's Avatar
thanks for the fast reply, Ihave read your post here and believe me i did checked mine too after reading it, even though i just installed a brand new one the other day.
node0809 is offline
post #9 of 12 Old Jan 12th, 2008, 08:41 AM Thread Starter
node0809's Avatar
OK! found that darn puel pump relay switch....its under the dash, driver side...to the left of steering column almost on top that connector where you plug the code reader whenever you have a engine light on (sorry dont know what you call it) it has 4 wires going to it all black with blue, pink, white, and yellow tracers. i was fiddling and i happen to put my hand to it when i turn the ignition on, and i felt the click. changed it anyway...guess what? still the darn car wouldnt start...so I'm back to square one. I'm gonna retrace what i did, check everything again. maybe i missed something...wish me luck....and for those of you who dont know where that darn fuel pump relay switch?...now you know!!!! LOL
node0809 is offline
post #10 of 12 Old Jan 12th, 2008, 01:46 PM
P.O.S. Truckdriver
if you have spark and have fuel, check the vaccum lines. i did a sr20 swap and had just enough stuff hooked up so i could start it to check that i did the wiring right, or so i thought. i got fuel and spark, but could not figure why it would not start. i hooked up the vaccum lines and it fired up the first time.
Need parts?
91 SE-R Partout
96 200SX SE Partout
post #11 of 12 Old Jan 12th, 2008, 07:10 PM Thread Starter
node0809's Avatar
Well!!! after 2 maybe 3 hrs of trouble shooting i think I found the problem... its the distributor, I think its dead! Yes I did say that I have sparks! but my brother that works for the city garage came by to help me troubleshoot, recheck my plugs with a timing light, he explained that if i have a good spark the timing light will come on when i crank the engine..sure enough..the timing light didint lit up..we verified it by pulling the plug and while i tried to start the engine he watched for a blue spark..yes blue spark, thats was he said, he said yes i have spark but its weak. so we proceeded to check the coil resistance. my coil was nowhere close to spec. so im off to pick and pull junkyard tomorrow to see if i can find me a decent distributor....if not...im gonna have to fork up 300 bucks for a brand new one.
node0809 is offline
post #12 of 12 Old Jan 12th, 2008, 08:40 PM
P.O.S. Truckdriver
ive got one lying around somewhere i'm sure. post up in this thread if you are not able to get one.
Need parts?
91 SE-R Partout
96 200SX SE Partout
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
on my 3rd fuel pump xcaret B13 91-94 chassis 0 Nov 4th, 2007 11:11 AM
Fuel Pump Current x60079 U13 1993-1997 Altima 0 Oct 30th, 2007 09:27 PM
fuel pump kill switch callMeYourKiller B13 91-94 chassis 7 Dec 26th, 2005 04:14 PM
maybe this can be added to the nitrous sticky? buffdaddy18 Forced Induction & Nitrous Oxide 4 Dec 15th, 2005 08:20 PM
Fan modifications... samo GA16DE 1.6L Engine 25 Jun 20th, 2004 10:09 PM
You may post new threads
You may post replies
BB code is On
