when i start my car the enigine will lope and die if i dont give it gas i have replaced the iacv still didnt help. could someone tell me what is wrong with my car.
I would say the fuel pump. That's what my dad's truck was doing when his fuel pump was putting out about half the pressure it was supposed to (loped upon startup and died when you put it in gear).
Wierd. Mine did the same thing and I fixed it by replacing the IACV. Might want to check the connector on the harness as well. On mine the sping pins on the inside of the harness lost the spring to them and intermittently lost contact resulting in strange things. I had to take apart the plug and pry the contacts apart.
You can diagnose an IACV by unplugging it. If it runs better, that's the culprit. A fast loping would suggest a vacuum leak. A slower lope would make me think insufficient fuel (possibly filter - a quick fix), insufficient air (check your filter).
I've now got a KA24DE and a GA16DE. Where's the TURBO?!
