Old Jul 27th, 2007, 06:26 PM   #1 (permalink)
talllittleman
Smile 1.6 Valve Adjust? Or maybe somthing else.
Ok so in this forum I mostly have found my awnsers by searching when I have a problem, but maybe I have not searched enough. Its a 98 B14 with 113k and Air intake, obx headers, heel toe racing batery in the trunk 2"exhaust with magnaflow cat, msd wires.
So it is making a mean valve noise that is loud it is there at idel (idels fine rpm wise) and and 5th at 60mph no matter what its there. Now I know that the valves need to be adjusted on these motors about every 30k now could this be it....
I dont know but the write up in my haynes mannel seemed rather in depth, with this what could be the sound. And how do I fix it any thing could help. Just trying to take a short cut I can record the sound and post it if that helps.
thanks
talllittleman is offline   Reply With Quote
Old Jul 30th, 2007, 09:26 PM   #2 (permalink)
IanH
Post Freak
IanH's Avatar
thanks
probably upper timing chain tensioner and guides need replacing. listen with large screwdriver as stethoscope. if you search here others have this problem.
good luck....
1997 Sentra GXE .... SOLD
1997 S-ER 5 sp yea !!!
2003 Pathfinder SE 4WD
IanH is offline   Reply With Quote
P1110 Intake Valve Timing Control Solenoid error! By Nature GA16DE 1.6L Engine 7 Aug 21st, 2008 10:51 PM
95-99 GA16DE Codes DraftEm98 GA16DE 1.6L Engine 5 Aug 19th, 2008 03:27 PM
how can i change the egr valve?? (96 sentra) morethanasentra B14 95-99 chassis 10 Aug 22nd, 2005 10:58 AM
EGR control valve...... qinsac SR-Series Engines (DE/VE) 6 Oct 11th, 2002 09:54 PM
Wastegate Valve Control Solenoid Valve? PULSSSAR Forced Induction & Nitrous Oxide 0 Jul 9th, 2002 04:16 AM
