Timing help! Yes I read the sticky
So I though I would check to see if any of my problems were related to timing. I followed the guide. The problem is, I cant see any of the timing marks unless the timing light is set to 60* advance (timing light works properly) and timing is retarded all the way then the pointer is close to the timing marks..... what would cause the marks to be that far off? Also does anyone have any tips for finding TDC on cylider 1 without useing the timing marks on the crank pully?
