Old Jul 7th, 2007, 09:14 PM   #1 (permalink)
dakota7557
Will a 4 prong MAF fit 3 wires?
Hi, I have a 99 Nissan Sentra and I am about to change the MAF. The problem lies in the area of the connectors. My 99 (1.6 automatic), has 3 prongs on the MAF. Will a MAF from 1997 fit my 99?? (which has 4 prongs and the numbers match on the red tag)...I've been having conflicting opinions on whether or not the 97 will fit on the 99...I'm sure someone out there knows this answer. Thank you, Jody
dakota7557 is offline   Reply With Quote
Old Jul 8th, 2007, 03:08 AM   #2 (permalink)
No-Pain
No-Pain's Avatar
Send a message via MSN to No-Pain
I assume you know part numbers for a new and old MAF. I'd suggest you to try to google the pin-outs of both MAFs and compare them. That's where I would begin searching.
- No-Pain -
Nissan Almera (equal to Sentra) 1997 1.6 litres
Mods so far:
-Added disc brakes to rear
-All corners have got new springs and shock absorbers (monroe reflex)
-custom made 4-->1 exhaust manifold with 2" piping -Some cool kameleont painting
-Head work done. Porting, some valve job (lightening, cleaning and polishing). Intake- and exaustports on the head totally re-designed and grinded.
-Some gauges: oil temp, oil pressure, fuel pressure, meter, lambda and external rev. meter with change ligth
-Free flow air-filter (calculated intake pipe lenght) with CAI.
-Lightened battery, moved to back
- No-pain -
No-Pain is offline   Reply With Quote
Old Jul 8th, 2007, 10:48 AM   #3 (permalink)
dakota7557
I have googled it with both numbers, I have looked up every possible method I know how and now I would simply like a warm body with first hand experience out there who has tried interchanging a 97 MAF for 1.6 to a 99 MAF with a 1.6...Thanks, Jody
Old Jul 10th, 2007, 09:42 AM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
It should plug in with no issues. As far as it working goes, I am not 100% but I believe it will, here's why I think that.
When the turbo GA guys use the 240SX MAF it is a 3 wire vs 4 wire difference and it works just fine. I believe the difference to be two ground wires VS. one ground wire. I personally used the 240MAF and then upgraded to the cobra MAF which also uses 4 wires and all I had to do was add the ground.
In either case you can make it work as long as the connector is the same you can easily probe the wires as there are only 3 different functions and change them around if necessary.
Wires are as follows.
5 v signal wire (.05 - 5.11)
ground
12 v power wire
If it has 4 wires I believe it simply utilizes two grounds.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jul 10th, 2007, 11:03 AM   #5 (permalink)
dakota7557
Thank you for the reply. You are absolutely right. I tried it and it worked. The cel is on so I will have to reset it. Thanks so much for taking the time to answer. Jody
MAF or harness problem? bobuddy Truck & SUV 3 Jun 22nd, 2007 08:40 PM
MAF problem with 96 sentra Kraizevoodoo General Discussion 0 Jun 7th, 2007 08:04 PM
how long is your MAF? pete? GA16DE 1.6L Engine 5 Jan 21st, 2005 09:14 PM
New Big Brake Kit-Test Fit YOUR Wheels on my car at Sunday's meet kwd2kSE Houston Nissan Enthusiasts 2 Dec 13th, 2003 11:37 PM
Spark Plug Wires... SE-R_krushalot B14 95-99 chassis 7 Nov 24th, 2002 03:51 PM
