My first guess is electronic ignition controller unit. Customers tell me pretty often that car stalls after a while of driving or wont start when being warm or won't start at all (and doesn't either give a spark). So there's a good change that you find your fault from ignition controller.
You can try to determine whether a spark comes to an engine or not when it does this stalling thing. It's easy, just unplug one ignition wire from then engine and attach an old plug to it and see what happens. If spark is totally gone it's pretty propable that ignition controller is broken.
- No-Pain -
Nissan Almera (equal to Sentra) 1997 1.6 litres
Mods so far:
-Added disc brakes to rear
-All corners have got new springs and shock absorbers (monroe reflex)
-custom made 4-->1 exhaust manifold with 2" piping -Some cool kameleont painting
-Head work done. Porting, some valve job (lightening, cleaning and polishing). Intake- and exaustports on the head totally re-designed and grinded.
-Some gauges: oil temp, oil pressure, fuel pressure, meter, lambda and external rev. meter with change ligth
-Free flow air-filter (calculated intake pipe lenght) with CAI.
-Lightened battery, moved to back
- No-pain -
