Cannot replace valve cover spark plug seals - Nissan Forum
post #1 of 6 Old May 27th, 2007, 01:53 AM Thread Starter
Question Cannot replace valve cover spark plug seals
The valve cover spark plug seals appear to be underneath some sort of tan (maybe it was white to begin with and turned tan/brown cause of the oil hitting it over time) plastic piece and this piece seems to be "ADHERED" to the top valve cover. I did not know this and when I tried to pull the piece where it looks like you'd pull to take it off it just cracked a piece of plastic off. I put it back together with some gas/oil resistant adhesive/sealant and its on there really good now again. In any case I received with a new valve cover gasket new spark plug seals and while I don't believe the old ones were leaking of course I wanted to replace those too since I had them. It appears as if you'd have to buy an entire new valve cover to replace the spark plug seals? IS THIS TRUE? ANYONE ELSE RUN INTO THIS ON A 1999 NISSAN SENTRA GXE WITH THE GA16DE TWIN CAM ENGINE?
searcherrr is offline
post #2 of 6 Old May 27th, 2007, 11:29 AM
I replaced my valve cover gasket on 92 Sentra. Replaced 11 grommets as well as small rectangle square inside the valve cover.
I also brought spark plug seal. When I tried to pull the old seal it broke apart. We were in a panic. Finally my brother figured out by comparing the old and new spark plug seal. The new seal was bigger. The old spark plug seal is imbedded in a STEEL RING. You have to bend the steel ring in order to get it outl. ( The valve cover is Cast Iron). We replaced one spark plug seal and left the other three alone since there wasn't any oil leak on spark plug.
I wanted to make sure the valve cover fits on again. The new spark plug seal was put on with a wood and tapping with hammer.
MisterRx is offline
post #3 of 6 Old May 27th, 2007, 07:50 PM Thread Starter
Question
I left the old ones on too and just cleaned them. They weren't leaking either. The 1999 Sentra GXE GA16DE engine has a plastic valve cover, but sounds like the same thing that it was embedded into it as you experienced as well. I don't understand this. Why would valve cover gasket kits come with the spark plug seals if they can't be replaced without buying a totally new valve cover. ANYBODY?
post #4 of 6 Old May 27th, 2007, 08:21 PM
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
when i pulled mine off they were stuck to the cover as well, altho i did not try to remove them
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline
post #5 of 6 Old May 30th, 2007, 12:20 PM
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
The B14's are shrouded by plastic, I have seen people use a pry hook tool to remove them and put new ones in.
The B13 has a metal valve cover and the seals are easy to replace...
wes is offline
post #6 of 6 Old Jun 19th, 2007, 05:09 PM
my plastic cover on my 98 200sx has no replaceable seals....it does have and integrated seal which is permanent to the cover. nissan wants 150.00 for a new cover but i am a machinist and thought i would try something different. i bought a gasket kit which i am assuming those seals were for the aluminum valve cover. i cut out the original seals on a cnc mill at work and bored them for a light press since the cover is plastic (about a .001 press fit) it was a success and it only took about 30 minutes to do. they are installed and working good.
97s14 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
Automatic Transmission Filter / Screen Change - Valve Body Removal + Reinstall Ralliart16 GA16DE 1.6L Engine 11 Dec 10th, 2015 10:07 PM
Spark plug tube seals on the 1.6? DaDusterDude GA16DE 1.6L Engine 8 Jan 20th, 2005 07:24 PM
Spark Plug Tube Seal Gone maduncs B13 91-94 chassis 1 Apr 29th, 2004 09:55 AM
Valve Cover Gasket Replacement mr_wright1911 U13 1993-1997 Altima 1 Apr 13th, 2004 04:18 PM
sr20det spark plug cover oasaturiwa New Member Forum 1 Jul 7th, 2003 09:24 PM
You may post new threads
You may post replies
BB code is On
