quote:
Originally posted by vetboy93
on a recent major tune of my 93 sentra with a ga16de engine i noticed a slight oil leak on the back side of the engine on some type of "sensor" "it has a wire comming out of it so i guess its a sensor of some type my manual says nothing about this part or even what it is, it is on the back side of the block and slightly above and to the right of where the oil filter spins on, it seems to be leaking engine oil out of it not a tremendous amount but id like to change it before it gets any worse, any savy sentra people here know what this is ? or what it does?, at this point im almost ready to walk into the parts store and ask for a hickamadoodle, or a thingyamagig or at least a whatchamacallit!
That would be your oil pressure switch sensor for your "dummy" light. They cost around $12. It's a common place to leak oil on SR20's too. You have to get it at a dealer. No parts store would carry it.
this is from an older thread. I have the same leak, so I'll be trying this soon.
Hope this helps.
Josh
