Old Jan 15th, 2003, 02:12 AM   #1 (permalink)
kbrassfi
Nissan Fanatic
kbrassfi's Avatar
Send a message via AIM to kbrassfi Send a message via MSN to kbrassfi Send a message via Yahoo to kbrassfi
valve adjustments
I was in my engine compartment the other day and my engine was sounding like the valves need adjusting I am at 102,000 and since I have had car have not had this done is this something that is easy or something I should have someone else do? thanks for the help also if it is something I can do if any of you can point me in the right direction I would appreciate it
kbrassfi is offline   Reply With Quote
Old Jan 15th, 2003, 07:25 AM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Post Not easy.
WHile it can be done it is not easy. The adjustments are made vis shims with the valve train assembeled, this takes some special tools and time. CHeck out the FSM for the procedure to see if it;s something you want to tackle.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jan 17th, 2003, 12:36 AM   #3 (permalink)
Sethticlees
Nissan Addict
Sethticlees's Avatar
I read the FSM and yes the procedures looks intimidating.
I'm just wondering has anybody done it?
If so, would you mind sharing your experience with the rest of us?
Seth
Sethticlees is offline   Reply With Quote
Old Jan 17th, 2003, 12:50 AM   #4 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
this may be helpful
http://www.sr20development.com/Instr...ALL-GA16DE.PDF
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Jan 17th, 2003, 06:31 PM   #5 (permalink)
wes
Wise Cracker
wes's Avatar
Post Great link.
ALthough the factory manual has a different way of checking tolerances. JWT provides cold tolerances while the FSM provides hot tolerances. YOu can remove and adjust the shims with the valvetrain assembeled, it is outlined in the FS and requires some special tools.
JWT
www.notnser.com
Old Jan 19th, 2003, 04:09 AM   #6 (permalink)
kbrassfi
Nissan Fanatic
kbrassfi's Avatar
thanks guys I appreciate it, this at least gives me a starting point if I decide to do it myself or not
My 96' 200sx
