Old Dec 26th, 2006, 08:14 PM   #1 (permalink)
krishna
krishna's Avatar
WISH IS A FASTER ENGINE FOR A SENTRA 92
MY CAR HAS A GA16DE ENGINE BUT ITS ON ITS LAST RUNS..
DO I FICKS THE ENGINE ORE CHANGE, IT AND FORE WISH ONE
THAT WILL GIVE MY CAR MORE POWER AND SPEED
OFF HOW MUCH HORSE POWER ARE WHE TALKIN ABOUT
krishna is offline   Reply With Quote
Old Dec 27th, 2006, 11:47 PM   #2 (permalink)
hksilvia
hksilvia's Avatar
you can turbo the ga16, but you would have to get the engine rebuilt with low compression pistons, and other turbo parts. if you want it to last long under forced induction. or you can get an sr20det from japan but you will have to swap everything from axles, tranny, brakes, mostly the whole front end of an se-r to youre car.
Good luck!
hksilvia is offline   Reply With Quote
Old Jan 2nd, 2007, 10:16 PM   #3 (permalink)
ilikespeeding
Step 1: Sell POS
Step 2: Buy real car
1990 Eclipse GSX - Money Eater
1996 Eagle Talon TSi - Wrong wheel drive
1996 Sentra GXE - Daily Driver
ilikespeeding is offline   Reply With Quote
Old Jan 4th, 2007, 06:28 PM   #4 (permalink)
krishna
krishna's Avatar
ufff all that id prefer the turbo but where can i get one (not that expencive)
and how can i get a list off the parts that i would have to change for the engine to work longer
thanks.
step 1 and 2 its so easy but i woudent get that much for it. and it was a gifth for free just have to fix it
Old Jan 4th, 2007, 08:17 PM   #5 (permalink)
ilikespeeding
thanks.
Just to give you an idea, there are two choices for a faster sentra. One is a motor swap, the other is slapping on a turbo.
For the turbo:
1) $400 15G turbo - 5PSI
2) $100 Downpipe
3) $100 Turbo Manifold
4) $100 Fuel Pump Rewire & Pump
4) $100 Fuel Pressure Regulator
5) $150 Injector
6) $50 DSM Side mount
7) $40 DSM Blow off valve
8) $100 Pipe kit
9) $200 Oil Feed/Return line
10) $150 Metal Head Gasket
11) $100 Oil cooler
12) $50 Cold range spark plugs
Total: $1,740 USD = $19,000 pesos without shipping.
That is far more than the car is worth. Plus, that isnt all that reliable. The engine swap for the SR20DET is done locally for about $5,000 USD which is about $55,000 Pesos.
Old Jan 7th, 2007, 12:52 PM   #6 (permalink)
krishna
krishna's Avatar
Q.....?
how much can i ask for the car $$$$
its a 92
i dont know the model
title its salvage
it has an air intake
17000 milles
it runs ,not the way i want it ,but it runs
i got a friend that has a toyota mr2 85 man that car runs fast what can u say about that car
i also like the datsun fairlady but thats a big investment dont you think
What car would you recoment me buy...........
Old Jan 7th, 2007, 07:17 PM   #7 (permalink)
ilikespeeding
Q.....?
its a 92
title its salvage
17000 milles
Is the MR2 turbo? If so, and it's healthy, it's a nice car. The sentra isnt worth much money; it really depends what's wrong with it. Since you said it bearly runs, I'm guessing the car is worth about $400.
I believe the mexico bought the stamps to the 1967 Impala. I'd say go buy a 2007 1967 Impala before you spent all that money on a sentra. That would be pretty boss.
Old Jan 9th, 2007, 05:45 PM   #8 (permalink)
krishna
krishna's Avatar
nop no turbo it no even super charged its the standard only.its less than an ton.... whe only changed the trany from a mr2 87 since the 86 and before have a defect they pop out 3 and 5 gear its burn out up to 3 gear.
i dont have that much money to buy that car
let IT be more cheap BUT NOT SLOW W=HAT DO U THINK OFF THE DATSUN FAIRELADY THE 240 LIKE 65 75 IN BETWIN GOOD ORE BAD ORE NOT WROTH IT THE SENTRA RUN BUT NOT HOW I WOULD LIKE FORE IT TO RUN
THE CAR WAS 800 DLLS NO TITLE I PAIED 150 DLLS FOR IT PLUS THE PART THAT I BOUTHG FOR IT LIKE OIL ,CLUTH,GASKETS FOR THE HEAD AND THE ONE FROM THE OIL ,STARTER,BATTERY, THE TOP OFF THE CAR (THE INSIDE COVER )AND SEVERAL ACCESORIES,THE FRONT AXES 2 A LOT OFF MONEY THE GOOD THING IS THAT MY DAD WORKS IN A DISTRIBUTER FOR AUOMOTIVE PARTS SO SOME PARTS ARE MORE CHEAP .......
SE U AROUND .....
Old Jan 9th, 2007, 06:27 PM   #9 (permalink)
0341TODD
FIVE SPEED&FOAM INJECTION
0341TODD's Avatar
SE U AROUND .....
Dude, are you guys talking to yourselves here?!?!? You are arent you
Id love to live in Tijuana!! I think you should put a vg30et in it and convert it to rear wheel drive!!! That would be awesome!!!!! The parts would be cheaper then anything else!!!
Lets see.....welder, torch, motor, tranny, r-200, raw steel tubing, time................
ONE OF THESE DAYS I'LL FIGURE OUT HOW TO CHANGE MY WIPER BLADES
0341TODD is offline   Reply With Quote
Old Jan 9th, 2007, 07:46 PM   #10 (permalink)
ilikespeeding
....motor mounts, drive shaft, differential, wheel hubs, some odd gas tank config, ect.
Doing a RWD conversion costs way more than its worth.
Old Jan 14th, 2007, 03:27 PM   #11 (permalink)
krishna
krishna's Avatar
come on RWD i mid be cheap but it will take too long.... i would d it ad i wont have a car till its done
id bee easyer to buy a SR20DE in ecology auto parts for 150 dlls and then fix the engine if i make it turbo
i bet you have a metro phone right, crappy JA used to work fore them..
Old Jan 15th, 2007, 01:29 PM   #12 (permalink)
Unreal~Designs
Send a message via AIM to Unreal~Designs
Good luck!
The cars compression is low enough to put a small turbo on...
a VG30et... ummm, way to much modification for the worth... and converting to RWD would take far too much.
The most uncomplicated answer would be to get a SR20VE or SR20DE(T)
Anything else is pretty much useless by one means or another.
1998 Nissan 200SX SE
Unreal~Designs is offline   Reply With Quote
Nissan Recalls 200,866 Altima, Sentra Sedans to Fix Engine Part Steve Nissan News 0 Jul 12th, 2006 08:36 AM
Engine Knock on Mexican built GA16DE Sentras Pablo14 GA16DE 1.6L Engine 44 Jul 5th, 2006 10:16 PM
89 Sentra engine doesn't start on.register E/CA-Series & GA16i Engines 11 May 14th, 2005 08:54 PM
'94 Sentra LE Engine Swap pimpride B13 91-94 chassis 3 Mar 31st, 2005 09:09 PM
Help - Engine Head cracked - 97 Sentra spencersimon B14 95-99 chassis 2 Oct 10th, 2003 02:47 AM
