96 Sentra GXE will not start
I have a problem with my 96 Sentra GXE. The timing chain has been rattling for awhile, so I believe the tensioners are gone, but the main problem is that I drove it friday with no problem and shut it off. I let it sit all weekend, and this morning when I tried to start it, all it would do is turn over,(rrr, rrr, rrr) but would not run (vroom). I've changed out the fuel filter and the spark plugs and I checked the ECU and it gives me a code of 0505, which means "No self diagnostic failure indicated." I also checked to make sure that there was spark from the spark plugs and there was. The fuel pump is humming so I don't believe that it is bad. Does anyone have any idea of what it might be? Is there a possibility that the timing chains jumped a tooth? Thanks in advance.
