Old Nov 20th, 2006, 04:53 AM   #1 (permalink)
Dan9
Certified Ghetto Mechanic
Dan9's Avatar
Post header secondary touches oil pan - problem?
Found this dead old thread: http://www.nissanforums.com/ga16de-1...ouches+oil+pan
Now before I installed my Hotshot header on my first motor I painted it with a couple coats of ceramic high heat paint, on top of what I guessed was already ceramic coating, so I think they retain more heat than just metal pipes.
On my old motor the clearance was about 1/8" but after the swap the pipe touches the pan.
I only started to think about this because of my small temp gauge reading high problem.
So, definitively, is it OK for the exhaust to touch the pan? Isn't the pan there to cool the oil as well?
And secondly, can I bang in that part of the oil pan a bit to make it clear or will that mess up a sipper or somethin?
Maybe I will try and see about extra gasket miracles...coiuld change the geometry a bit and make it clear...or an extra flange, as suggested in the end of deadthread.
D
I like my tin can car
Dan9 is offline   Reply With Quote
Old Nov 20th, 2006, 12:38 PM   #2 (permalink)
EvilPotato
EvilPotato's Avatar
my secondary pipe rattled against the oil pan when in reverse, what i did was bang the oil pan in just enough to give the pipe some clearance and it doesn't look like i damaged anything inside the pan. my car is a '96 though.
"...and the Lord said to John, Come forth and ye shall receive eternal life, but instead John came fifth and won a toaster."
EvilPotato is offline   Reply With Quote
Old Nov 21st, 2006, 04:17 PM   #3 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
do not hammer the pan out. It is easier and safer to use an extra gasket or flange or to have that section of the header modified!
www.NissanPerformanceMag.com
JWT
www.notnser.com
Problem w/ HS header... anyone else have this happen?!? Avshi750 GA16DE 1.6L Engine 16 May 3rd, 2005 12:20 AM
Stillen Header and Secondary Pipe whitespecv QR25 2.5L Engine 3 Jan 4th, 2005 01:55 PM
Oil leak around oil pan chuckd General Maxima Discussion 2 Nov 15th, 2004 12:46 PM
GA16DE Oil pump problem? BigDumbRedneck B13 91-94 chassis 5 Mar 30th, 2004 04:21 PM
hotshot header problem jamesnismo QR25 2.5L Engine 7 Sep 7th, 2003 08:41 AM
