Old Jul 14th, 2006, 10:05 PM   #1 (permalink)
Clem91
Clem91's Avatar
Lightbulb Clutch Replacement
Great news! I've come to accept the fact that I have to replace my stock clutch, being as it is on it's last leg, I'd rather replace it now before it blows, rather than be stuck in college with a blown out clutch, since I'm leaving in about 4 weeks!
So here's the question: Since I'm replacing the clutch, I figure I might as well go big and throw a Stage 2 Clutch Master in there, but honestly I don't know much about clutches to begin with, besides that Stage 2 is the best. Is there a great difference between the other stages? Should I get a Clutchmaster or ACT? Is there a huge difference between the brands? Has anybody replaced their clutch, if so how is it?
I also lifted the car up and noticed the CV Joint was leaking. My supervisor told me that the CV Joint has to be removed in order to remove/install clutch, should I have them replace the CV Joint while it's all taken apart? My sup. says I should and to get a Remanufactured Ball Axle, or something like that? I know even less about the CV Joint problem than I do the clutch so any help would be much appreciated! Thanks!
Clem
-91 Sentra SE, GA16DE: Hotshot CAI, New Head Unit, Speakers, 2 12" Subwoofers w/Subamp,
Xenon Headlights, iPod integration, Coconut Air Freshener-
Clem91 is offline   Reply With Quote
Old Jul 16th, 2006, 06:02 PM   #2 (permalink)
brycestejskal
Send a message via MSN to brycestejskal
I believe Clutch stages go all the way up to stage 4 but dont quote me on that. The higher the stage number the harsher the engagement and less "streetable" they become.I did a clutch replacement myslef about 8 months ago, working on it for about 6 hours a day for 3 days having never worked on a car in my life. I also had bad looking cv joints so i just went to my local autoparts store and got new ones with a lifetime warrenty. My replacement clutch was a centerforce Heavy Duty clutch however if i were to do it again i would have gone with ACT. Also, make sure the surface of your flywheel is lookin good. And if you have the money, i would recommend a lightweight flywheel while everything is off. If you decide you want one later you will wish you had done it when you had everything apart.
brycestejskal is offline   Reply With Quote
Clutch Replacement time... SergioCR GA16DE 1.6L Engine 0 May 31st, 2006 09:12 AM
Looking 4 Guidance - '88 D21 Pickup Clutch Replacement cgh1 Truck & SUV 4 Apr 24th, 2005 06:54 PM
Can someone provide a complete part list for Clutch Replacement ('90 Pathfinder) htabbas Truck & SUV 7 Jan 25th, 2005 04:38 PM
Questions about clutch replacement on 93' Sentra XE defensive B13 91-94 chassis 3 Oct 19th, 2004 05:51 PM
clutch cable replacement shughes GA16DE 1.6L Engine 0 Oct 12th, 2004 12:18 PM
