Old Jul 12th, 2006, 11:30 AM   #1 (permalink)
lmoorefx
lmoorefx's Avatar
The best air fuel controler??????
So I was wondering what, if any, air fuel piggy back system you all are using to tune the air fuel mix on the GA16. I have a hotshot header, Hotshot CAI, and have a high flow magna flow cat, with a 2.25 inch exhaust system. The gas mileage has gone down abit and it seems to be running rich. I havent advanced the time yet but want to be able to tweek the mix, Any suggestions as to what to do? Thanks!!
http://www.larryrmoore.com
94 Sentra XE
Hotshot header
Hotshot CAI
Unorthadox Underdrive pully
Nology Hot wires
Max ground kit
Magnaflow cat
Pacesetter 2.25 inch exhaust
B&G sport springs
NX Front and rear brake upgrade
Russell steel brakelines
lmoorefx is offline   Reply With Quote
Old Jul 12th, 2006, 01:52 PM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Sounds like you are headed in the right direction with your mods. Before I did any tweaking I would put the car on a wideband/dyno and see what the actual AF ratio is. Then make a determination as to weather or not your assumption is correct. This is certianly cheaper than a good AF controller if it turns out to be running right, and will also tell you how far you have to go with it.
The SAFC is something a lot of people use and it appears to work pretty good, although if it is only marginally off then perhaps an AFPR might be enough adjustment to lean it out a bit. Again knowing where it actually is on an accurate wideband would tell you what the best route is.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jul 13th, 2006, 10:01 AM   #3 (permalink)
lmoorefx
lmoorefx's Avatar
Cool thanks, I do plan on getting it on a dyno in the next few weeks to see where its at. I am curious to see the HP gains I have made with the mods that I have. The next step for me after getting it tuned is JWT cams and ECU. But I also want to race this car SCCA style and im not quite sure where I need to stop the mods in order to be in an approprate class. I also need to get a tach in this car, I was looking for a set of SE-R gauges but they seem hard to find, any suggestions as to an alternative? Thanks again!
94 Sentra XE
Hotshot header
Hotshot CAI
Nology Hot wires
Max ground kit
Magnaflow cat
B&G sport springs
Old Jul 13th, 2006, 10:13 AM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
If you are 100% sure your going to do the JWT cams and ECU I would wait on the AF controller.
As far as Scca are you talking autocross? If so then I would approach it one of to ways. Either research a specific class you want to run and prep it to the limit of the rules of that class. OR if you are just going to run it for fun, build what you want and don't worry about what class you wind up in!
JWT
www.notnser.com
OBD II Code Chart no1see2me QG18 1.8L Engine 7 Oct 21st, 2006 12:36 PM
Article: Why a 2.5" MAF to TB pipe is better than a 3" for a CAI oliverr87 GA16DE 1.6L Engine 4 Feb 10th, 2006 10:11 AM
Air Fuel Gauge Installation Help Chuck GA16DE 1.6L Engine 15 Sep 29th, 2005 06:46 AM
help! car shakes/bogs so bad it can hardly drive! Solidox2k B13 91-94 chassis 24 Oct 16th, 2004 07:13 PM
2001 Frontier Fuel Air Metering Code watrprf Truck & SUV 0 Oct 12th, 2004 09:20 PM
