Old Jul 11th, 2006, 09:44 AM   #1 (permalink)
pajim17057
How to replace spark plug tube seals?
I hope someone can help me with this. I got new spark plug tube seal and tried to replace them this morning. So I find this stupid plastic cover on the underside of the cover. So I figure it must just pop off. Well I start prying on it and it breaks it about 20 pieces. SO I was able to put the new seals in. BUT now need the plastic cover. My wonderful stealer says that the seals arn't serviceable and must buy a new valve cover for 140 bucks. So now I need to find a new stealer after dirty F'in thives. So is there a way around this? This is the most rediculous nonsense.
pajim17057 is offline   Reply With Quote
Old Jul 11th, 2006, 01:18 PM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
You can replace the seals, others have done this in the past. Now that you have busted the VC you need to replace it though, look for aused on here on the forums or in a junk yard and save yourself a hundred bucks.
You can also get the valve-cover from the B13 GA16 cars. They are metal and have replaceable seals and such.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jul 11th, 2006, 08:49 PM   #3 (permalink)
DaDusterDude
I think your problem is that you have a newer B14 car (like a 200sx) that has a plastic valve cover. I ran in to this same problem and on those the seals are not replaceable and they want you to buy the whole new valve cover for a bunch of money (I thought it was a joke too). You are still OK though as you can just go get a B13 valve cover and put your new seals in that one as it fits just the same as the plastic one. That is what I did because then when the seals start leaking again I just need to buy the seals which are a lot cheaper. When I did my change over I just went to the local junkyard and the valve cover is pretty cheap. You can leave it as is and just clean it up or I actually used black wrinkle paint on mine and sanded down the raised letters to make it look better.
DaDusterDude is offline   Reply With Quote
Old Jul 12th, 2006, 02:20 PM   #4 (permalink)
Slayer2003
Peek-a-boo....
Slayer2003's Avatar
Send a message via AIM to Slayer2003 Send a message via Yahoo to Slayer2003
Go to a junkyard, and pick one up.
You can also use one from a B13, 90-94, it's white, and aluminum. BE SURE TO KEEP THE BOLTS, AS THEY ARE SHORTER/LONGER THAN THE PLASTIC COZVER(dont remember if its shorter or longer, i just remember that part.) Just make sure to buy a new B13 gasket.
I pick them up for around $15-40, depending how much of an ass the guys are.
Originally Posted by RoadWarrior - ocforums.com
Yes, SATA is faster however..... putting full spec formula one tires on a 1.6L stock honda civic will not make it capable of 200Mph......
SEARCH BUTTON. USE IT OFTEN!
Slayer2003 is offline   Reply With Quote
VG33E 3.3L V6 spark plug replacement soapsuds Frontier 2 Jun 4th, 2006 09:29 AM
Spark plug cap guitarsage U13 1993-1997 Altima 3 May 26th, 2006 12:26 PM
Spark Plug Installation Steps? lotus197 GA16DE 1.6L Engine 8 Sep 22nd, 2003 04:51 PM
Exhaust and Spark Plug Questions... Mack GA16DE 1.6L Engine 10 May 10th, 2003 02:06 PM
Tried the nos........ wglenn B14 95-99 chassis 34 Dec 4th, 2002 05:09 PM
