Old Jul 9th, 2006, 04:48 PM   #1 (permalink)
ramprat
Send a message via AIM to ramprat
turbo 1.6L - Wes help
alright im posting this specifically for Wes but if anyone else has any input please feel free.
we're going to turbo my 1.6L 200sx for shits and giggles. it's going to run low, 5-6psi.
we have the turbo, we're fabbing a hotshot style manifold to clear the alternator and all that jazz. we are securing a side mount intercooler from a talon. the question is, the stock GA16DE injectors do not provide enough fuel for 5-6psi correct? they're like 185cc right? we're wondering the question because we've heard the stock SR20DE injectors flow 259cc which is good for 200hp. since we won't be making near 200 crank, more like 160 those injectors should be sufficient correct? and should we get the fuel rail from a sr20 also or are they direct plug?
the MAF. the maf i've heard can handle 180-200 hp is that also correct? we're thinking of nabbing one off of a 240SX since the plugs are the same, but we'd need to run a piggyback type of fuel management such as a SAFC to control instead of running the stock GA16DE MAF with a pressure switch to increase and decrease flow at needed rpms or when boost is present.
if anything should anything else be removed from the SR20 engine to be used for this project other than the injectors / fuel rail or should everything on the GA be sufficient?
as i mentioned this is just for fun as it will be low, low boost with a SMALL turbo. the turbo itself is only a .48/.63 Air Research off of a 1986 200SX CA18DET engine so even 160 crank might not even be there, but it's for fun.
any help would be greatly appreciated. thank you.
ramprat is offline   Reply With Quote
Old Jul 9th, 2006, 08:29 PM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
You can use the SR injectors but will need a means of controlling them. The MAF will top out at about 170 WHP. Again if you go to the 240 MAF you will need a means of controlling it. This ultimately leads to an e-manage or JWT ecu.
If you go e-manage just use the additional map sensor to piggyack the stock MAF.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jul 12th, 2006, 12:22 PM   #3 (permalink)
hdt
hdt's Avatar
you might want to try this link.
http://www.sentra.net/tech/garage/engine.php
97gxe sentra. ga16de, auto, cold air intake, catback,15inch rims,rockford sterio system,apc tack,apc fire bottle,
led neon under car kit, plugs,wires, sturt tower brace front and rear. coil overs, sway bars. drift front and rear kit, with exstream sides. jim wolf ecu, jim wolf cams.new mods ( junk yard in the sky ) RIP 14 aug 06 6am
2008 altima 2.5sl pebble beach. stock for now. bought 26may08 7:30pm
1964 ford falcon 2dr hardtop. 200 inline 6
2003 sporttrac xlt gold 260whp. xcal tune,intake,spacer, and full exhaust system
gone but not forgotten,
2004 buick rendezvous cx traded.
1997 nissan sentra gxe rip
1998 ford contur se sport
1992 ford excort lx hatchback
1980 chevy scottsdale 350,585 cranck hp
1987 isuzu pup
1964 vw bug
hdt is offline   Reply With Quote
Old Jul 12th, 2006, 01:40 PM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
I know that link inside and out. It really does not speak to his specific questions...
JWT
www.notnser.com
Old Jul 13th, 2006, 01:11 PM   #5 (permalink)
hdt
hdt's Avatar
wes is there a post on all the work you did on your ga16 to get 250whp?
1987 isuzu pup
1964 vw bug
Old Jul 13th, 2006, 01:41 PM   #6 (permalink)
wes
Wise Cracker
wes's Avatar
There is life outside this forum you know
Nissanperformancemag.com and notnser.com pretty much document the buildup.
JWT
www.notnser.com
Old Jul 23rd, 2006, 11:11 PM   #7 (permalink)
ramprat
well, i'm back. been busy and crap. the manifold has been made and everything is fitted. i decided to go with 370cc injectors to be safe, a LC1 with a SAFC II for tuning. as of now the car isn't boosting, it's bypassing until i can get on a dyno to properly tune it. what a bitch and a half to install, it's slung all the way towards the drivers side of the car to clear everything
Old Jul 24th, 2006, 10:13 AM   #8 (permalink)
wes
Wise Cracker
wes's Avatar
Lets see pics. !
JWT
www.notnser.com
Old Jul 24th, 2006, 12:40 PM   #9 (permalink)
ramprat
soon enough, im tryin gto get the SR20 throttle body to fit. it's a 95 TB going on a 96 GA upper.. people said it wont fit but uh wtF?
Old Jul 24th, 2006, 01:30 PM   #10 (permalink)
wes
Wise Cracker
wes's Avatar
If you have a B14 good luck. Search for posts that I made abotu this. It bolts up but does not have the IACV or FICD built in. As such you will have to sort out those items for it to work properly.
JWT
www.notnser.com
Old Jul 24th, 2006, 04:25 PM   #11 (permalink)
ramprat
yeah it's a b14, but i have a 2nd upper intake that i'm going to cut out a spot for it all or retrofit the B13 upper with a plate i made. i dunno. i just got my SAFC Neo, i ditched the SAFCII
Old Aug 27th, 2006, 10:17 AM   #12 (permalink)
turbo200sx
post some pix if this was finished
turbo200sx is offline   Reply With Quote
Compiling a list of factory turbo cars...please help himilefrontier Forced Induction & Nitrous Oxide 17 Oct 28th, 2007 10:23 PM
200sx turbo problem - any helpers? Plew Forced Induction & Nitrous Oxide 13 Apr 22nd, 2007 07:00 PM
1.6L to 2.0L turbo? Revolvo B13 91-94 chassis 3 Oct 6th, 2005 11:00 PM
BEFORE A TURBO!!! s13drift S13 240SX 1989-1994 12 Oct 4th, 2005 03:11 PM
Turbo b13pnoysentra GA16DE 1.6L Engine 3 Jul 17th, 2005 08:10 PM
