Old Jan 4th, 2003, 08:00 PM   #1 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
Send a message via AIM to HKS20DET
Angry help w/ crank pully removal
i have everything remove (belts, etc...) all i need now is to take the crank pully off to install a new front main seal. i dont have an impact wrench on hand so how would i go about taking this bolt off? even after putting the car in gear and holding the break firmly the nut wont budge (if u have done this job u will know what i mean) plus there isnt a whole lot of room for movement in the wheel well. any tricks. quick responces would be great. thanks
HKS20DET is offline   Reply With Quote
Old Jan 4th, 2003, 08:38 PM   #2 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Post Big ass breaker!
You might want to try a big ass breaker bar you can even use a pie as an extension to the bar to gain more leverege. Only trick I can think of without using an impact.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jan 4th, 2003, 08:50 PM   #3 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
well i might be borrowing an impact pretty soon. thanks though
Old Jan 4th, 2003, 08:57 PM   #4 (permalink)
Centurion
freakish poster
Centurion's Avatar
What about the "gehtto" impact? Hammer the breaker bar.
Centurion is offline   Reply With Quote
Old Jan 5th, 2003, 05:21 PM   #5 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
good thought haha. well i got it done. i borrowed a shitty impact wrench. wouldnt even break it loose. i got an idea form slamed150 when i was talkin to him on AIM. his idea was to get socket extensions to bring to ratchet outside the wheelwell (a breaker bar also). worked great. took 10 seconds. as for everything else, it all went real smooth. took a total work time of about 3 hours if any is interested.
oh also had to buy a pully puller. $20
Old Jan 6th, 2003, 12:59 AM   #6 (permalink)
javierb14
3 bar MAP
javierb14's Avatar
Send a message via AIM to javierb14
my ghetto breaker bar, i use the jack handle
www.full-race.com
Anything else is half fast!
866.FullRace
javierb14 is offline   Reply With Quote
Old Jan 6th, 2003, 11:14 AM   #7 (permalink)
sunnysentra
Nissan Addict
sunnysentra's Avatar
this is what I did. I placed the wrench handle against the side of the frame and then cranked the engine using the starter to loosen the bolt. This works, just make sure the handle of the wrench is tight against the body metal. I thenused a wedge like a metal chisel and just slightly tapped around the entire pully, it popped right off. To tighten, I put a crew driver in the hole of the pully and against the engine piece and then torqued the bolt on at the right amount.
Chris 92 classic
Part of the AUTO / MANUAL SWAP CLUB
sunnysentra is offline   Reply With Quote
Old Jan 6th, 2003, 12:20 PM   #8 (permalink)
Centurion
freakish poster
Centurion's Avatar
Well you answered my unasked question. I wasn't sure which direction the engine turned, but when seal time comes around I'll use that trick.
1993 Sentra XE auto (original owner)
2005 NISMO Frontier
Old Jan 6th, 2003, 03:51 PM   #9 (permalink)
HKS20DET
Nissan Addict
HKS20DET's Avatar
i did the same. worked good.
Chris 92 classic
i would be way to afraid to do this and mess something up.
