Old Apr 3rd, 2006, 08:44 PM   #1 (permalink)
lrosemond
Oil all over spark plug boot.
I pulled my #4 spark plug wire from the plug, and there's oil all over the boot. I can also see some oil in the hole where the spark plug is. The #1 spark plug wire is also the same way; #2 and #3 are dry.
Any ideas anyone? Is the problem the valve cover gasket?
Vehicle: 1996 NISSAN SENTRA GXE
lrosemond is offline   Reply With Quote
Old Apr 3rd, 2006, 10:24 PM   #2 (permalink)
phatmastaflip
phatmastaflip's Avatar
Send a message via AIM to phatmastaflip
i have the sr20de but i am thinking its the same reason why there is oil in the spark plug area. mine WAS the valve cover gasket. more specifically the gasket rings around each of the spark plug holes between the valve cover and the spark plug cylinder barrier area. should be simple... it was just removing a couple bolts change the gasket and torque bolts back. just my 2 cents.
http://i21.photobucket.com/albums/b2...taflip/sig.jpg
1996 200SX SE-R
NX nitrous 75shot, WR header, 2.5 Exhaust, WR Intake, Denso plugs, Accel Wires, 15" L7 Solobaric, Kenwood 1800watt, Panasonic MP3, panda seats, custom Fiberglass enclosure, 2-8" visor LCDs, PS2, metallic black paint, Drift front, homemade sides, BC rear, halos, smoked tails, shaved moldings, molded kit, shaved corners, KYB shocks, 17' deep dish 5 spokes, powerslot rotors
http://www.cardomain.com/ride/2140754
phatmastaflip is offline   Reply With Quote
Old Apr 6th, 2006, 01:12 AM   #3 (permalink)
fkmfkm
YEAH its the ring around each plug ..but for the ga16de...there is a cover covering the rings ...should I just pry out the ring ?
fkmfkm is offline   Reply With Quote
Old Apr 12th, 2006, 01:56 PM   #4 (permalink)
nbkoontz
nbkoontz's Avatar
I had this problem almost a year ago on my 1999 Sentra GXE. The mechanic told me that (apparently) on the 1995-1999 GA16DE that the rings, which he called the spark plug tube seals, could only be purchased with a new valve cover. He said that he searched everywhere and even talked to the parts department at my local Nissan dealer, to verify this. Therefore, the only way was to replace the rings (tube seals) was the costly route. He said the older Sentras (1994 and prior) were not this way. To make a long story short, I bought a new valve cover and valve cover gasket and this fixed the problem...until my front main seal went, but that is another story. I assume that his assessment was correct, in which case, you may be looking at the same type of work. Hopefully I wasn't taken to the cleaners on this one...
nbkoontz is offline   Reply With Quote
engine flush vs Bilstein Engine Flush vs not at all ak47m203 Off Topic 7 Feb 21st, 2008 03:06 PM
Oil in spark plug sleeve... 9double8 SR-Series Engines (DE/VE) 6 Jul 22nd, 2006 05:34 PM
Spark Plug Wires AnthMC GA16DE 1.6L Engine 4 Sep 1st, 2004 10:09 PM
Oil In spark plug holes Rottdog SR-Series Engines (DE/VE) 1 May 26th, 2004 07:17 PM
Spec V Spark Plug???? cloud QR25 2.5L Engine 4 Oct 3rd, 2003 12:06 PM
