» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > GA16DE 1.6L Engine
Old Jun 15th, 2006, 05:27 AM   #16 (permalink)
ramprat
Send a message via AIM to ramprat
i've tried this timing method with the light, i see absolutely no marks on the crank pulley.
ramprat is offline   Reply With Quote
Old Jul 15th, 2006, 02:28 PM   #17 (permalink)
Burn 17
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
you may just want to clean off your pully and needle. its hard to see if you have ac and all of the extras. but it does work i have done it several times.
NEW!!1987 300ZX
200 sx auto cross beast--
Intake, Front and Rear Strut bars, Major exhaust leak.98style tail lights, clear corners, and halo angle eyes, Hot Shot headers/Downpipe(still need money for the rest of it)
Mazda B2200 Mini Truck
Burn 17 is offline   Reply With Quote
Old Aug 12th, 2006, 09:54 AM   #18 (permalink)
SilverSentra99
Nissan Guru
SilverSentra99's Avatar
Send a message via Yahoo to SilverSentra99
ive advanced my timing and my idle is right but why do you think my idle doesn't stay up when i turn my ac on. its frustrating, when i stop at a light i now have to put my car in neutral and foot on the gas to keep it from dieing. i have a tach and when i turn it on the needle goes up but it comes back down to where it was before i turn it on. and then fluctuates and then finally dies. its like a 15-20 second process. but i also remember when it worked properly it would go up like 200 rpms and stay there to compensate for the ac being turned on and now it doesn't anymore , any ideas about this?
1999 Nissan Sentra GXE Limited Edition Auto GA16DE
See My Custom RAM/Cold Air Intake ,multicolor LED Undercar Kit Optix,K&N Filter Charger, Stock Gun Metaled Rims @ http://www.cardomain.com/ride/261891
SilverSentra99 is offline   Reply With Quote
Old Aug 20th, 2006, 07:55 AM   #19 (permalink)
zxt
On a carb engine, its prolly the idle up solnoid, not sure if its the same with EFI's.
@Oliver: Great job man!!!
zxt is offline   Reply With Quote
Old Sep 26th, 2006, 08:38 AM   #20 (permalink)
ConKBot of Doom
The IACV (the thing with the screw on it to adjust idle), also has a solenoid on for fast idle.
SilverSentra: how much did you advance your timing?
ConKBot of Doom is offline   Reply With Quote
Old Oct 28th, 2006, 04:33 PM   #21 (permalink)
Nikku
Hey guys, Im kinda new with all this. I have a few questions.
In Picture #4, do you have to use the inductive cable?
also do u have to use a light gun? what does the light gun do?
where is the crank/pulley with the marks?
Nikku is offline   Reply With Quote
Old Nov 11th, 2006, 01:11 PM   #22 (permalink)
Slick Rick
Could i adjust the timing by just loosening the distributer cap bolts without the gun?
Slick Rick is offline   Reply With Quote
Old Nov 19th, 2006, 12:04 AM   #23 (permalink)
zxt
Inductive cable? The light gun has an inductive cable and you need to connect it to number 1 ignition wire. The crank pulley is located opposite of the tranny, see those belts? Its one those pulleys...its at the bottom.
Old Nov 19th, 2006, 12:06 AM   #24 (permalink)
zxt
Yes of course. Thats the way to adjust the timing BUT you couldnt accurately tell whats your tiing without the gun.
You adjust the distributor to adjust the timing and you use the gun to see whats the timing.
Old Jan 31st, 2007, 05:54 PM   #25 (permalink)
deadlyrays
Send a message via AIM to deadlyrays Send a message via MSN to deadlyrays
ok i dont get what u mean by moving forward and backwards because in your last picture, moving forwards would make it go into the negative numbers u had put on the picture...so does moving forward mean turning it towards you or away from you ??
1995 200sx SE - needs sri intake pipe.
deadlyrays is offline   Reply With Quote
Old Jan 31st, 2007, 06:34 PM   #26 (permalink)
oliverr87
Nissan Fanatic
Send a message via AIM to oliverr87 Send a message via MSN to oliverr87 Send a message via Yahoo to oliverr87
forward means turning it away from you (clockwise). moving forwards DOES NOT make it go into negative numbers. get a timing light and you'll see what I mean
oliverr87 is offline   Reply With Quote
Old Feb 7th, 2007, 08:41 PM   #27 (permalink)
b13pnoysentra
The Classic Collector
Hey, this timing advance eats my gas mileage when shifting at 2500 rpm. But I started shifting at 3000 rpm RECENTLY, like you told me to do last year and WOW, i started getting more miles out of my tank. Thanks for the advice that I didn't follow til last week.
I'm also concerned about the higher PPM ratings I received in my recent smog test. Can you tell me what could be the problem: Smog Check (Luckily Passed)! - AllNissans.com - NPM Forums
Current Nissans:
1992 Nissan Sentra SE-R
2008 Nissan Frontier SE
2003 Nissan 350Z
Pst Nissans (they served me well):
1994.5 Nissan Sentra Limited Edition
1994 Nissan Sentra SE-R
1995 Nissan Altima GXE
1992 Nissan NX1600
b13pnoysentra is offline   Reply With Quote
Old Feb 26th, 2007, 02:45 PM   #28 (permalink)
deadlyrays
3000rpm should be the normal shifting rpm...well u could wait higher but ive always shifted at 3k. and i get what u mean by clockwise, its just that your picture , if u look at it again, if u stood infront of the car as u were adjusting the timing, moving the distributor towards urself would be going like 10,11,12,13 etc... and your last post said to turn it away from yourself ( if u were standing infront of the car) and that would technically retard the timing. thats where i was kinda lost at first lol
Old Feb 27th, 2007, 10:14 AM   #29 (permalink)
garyf0
Maybe you pros can answer a question for a newbie- I have a replacement engine that does not have a distributer or a crank pulley. Was told that it has a new timing chain. I have read that you can find TDC by hand cranking the pulley bolt until you feel compression coming out of the #1 spark plug hole. Is this correct?
garyf0 is offline   Reply With Quote
Old Feb 27th, 2007, 02:04 PM   #30 (permalink)
oliverr87
Nissan Fanatic
yea that works
Write-up: how to remove upper timing chain guide Harris SR-Series Engines (DE/VE) 20 Aug 21st, 2006 04:30 AM
ka24e timing chain guide deathtorice Truck & SUV 2 Jan 7th, 2006 02:58 AM
Upper Timing Guide [PICTURE] jerryclement S13 240SX 1989-1994 3 Nov 25th, 2005 07:06 PM
GA16I Timing Cover Guide Pins 4pt9fiero B11/B12/KN13 82-90 chassis 2 Jul 7th, 2005 02:41 PM
timing chain guide broken .. 97 pickup dwolf Truck & SUV 18 Oct 19th, 2003 06:16 PM
