Old Mar 1st, 2006, 11:36 AM   #1 (permalink)
JohnnyWash1
Banned
Of course.
JohnnyWash1 is offline   Reply With Quote
Old Mar 1st, 2006, 04:51 PM   #2 (permalink)
JohnnyWash1
Banned
Originally Posted by oliverr87
Did you set the car in timing mode?
There was some error with my last response--it is now the first post in this thread. Yes, I was in timing mode.
Old Mar 6th, 2006, 12:58 PM   #3 (permalink)
JohnnyWash1
Banned
Car makes popping noise under WOT or heavy throttle (please help!)
Ok, so my car makes a popping sound while under heavy throttle. The sound is accompanied by a hesistation in the acceleration, and the noise appears to be coming out of my intake tubing. I have two videos to help identify the problem. You may have to turn your volume up; the popping isn't as loud as it is in person. If it matters, the car does this while driving and while free-revving.
http://www.we-todd-did-racing.com/we...EzZGZkMzF5NTQx
If you have problems with the player, just click the Direct Download link below the video. Thank you everybody!
Old Mar 6th, 2006, 11:12 PM   #4 (permalink)
ghost_ryder35
Send a message via Yahoo to ghost_ryder35
does it affect performance at all? does your car have 200,000 plus miles on it? (no way related just thought thats what I saw on the guage cluster). Doesnt sound like a mis-fire, but if its coming from the intake tube thats gotta be bad. something in the engine might be bent. when was the last oil change? does it burn oil?
yea!!! my spec-v has vtec i can hear it at 6000 RPMS!!!! its so cool!!!
ghost_ryder35 is offline   Reply With Quote
Old Mar 6th, 2006, 11:13 PM   #5 (permalink)
ghost_ryder35
is everything in the engine bay sitting firmly in its position?
Old Mar 7th, 2006, 01:47 AM   #6 (permalink)
JohnnyWash1
Banned
Yes, it affects performance. The car hesitates when it pops. My car has 230K on it. Last oil change was a few hundred miles ago, but I might change it again just to be sure. If it burns oil, it does so discretely.
Old Mar 7th, 2006, 05:15 AM   #7 (permalink)
ghost_ryder35
man i dont know what to tell you, i have never heard that sound before in my life. maybe something to do with the timing chain, or water pump.
Old Mar 7th, 2006, 06:07 AM   #8 (permalink)
JohnnyWash1
Banned
Yes, I am thinking timing is off, and that maybe I am getting pre-ignition. It does sound like it's coming from the manifold, though.
Old Mar 7th, 2006, 06:21 AM   #9 (permalink)
ghost_ryder35
do you have a timing gun? that would be a real easy way to check?
Old Mar 7th, 2006, 08:03 AM   #10 (permalink)
JohnnyWash1
Banned
I don't have a gun--I would have already checked it. I'm going to try and find time this week to look at the situation more closely. If it truly is pre ignition, then this next tank should solve that as I will switch to 92 octane and see what happens.
Old Mar 9th, 2006, 04:20 PM   #11 (permalink)
JohnnyWash1
Banned
Need some help, people. Please give some input.
Old Mar 9th, 2006, 11:11 PM   #12 (permalink)
ghost_ryder35
did you ever check the timing? wat happened when you ran higher octane?
Old Mar 11th, 2006, 02:17 AM   #13 (permalink)
JohnnyWash1
Banned
I'm putting the higher octane in tomorrow, and I haven't checked timing yet.
Old Mar 11th, 2006, 02:32 AM   #14 (permalink)
JRinke
JRinke's Avatar
Send a message via MSN to JRinke
That sounds like a timing problem indeed. To fix it, just turn the timing to 10*, the factory setting. Or you can use colder spark plugs IF your problem is preignition. Do you have a perforance exhaust by any chance? I hear a lot of CRX's that sound like that......
1992 2-Door B13 GA16DE 1.6L 5-speed XE
JRinke is offline   Reply With Quote
Old Mar 15th, 2006, 02:58 AM   #15 (permalink)
JohnnyWash1
Banned
Ok, so I talked to a mechanic about my car and he agrees with you, Jrinke. He believes it is timing, but wonders if my distributor is broken. I really need a timing light to check the problem. I have a stock exhaust.
help with my 94 maybe Fuel leak? /bose/bad idle at times/ac heat? And handling? DonaldHays J30 1989-1994 Chassis 3 Aug 16th, 2005 07:56 AM
clicking noise when car is warm theofficer Stanza 2 Jul 21st, 2005 10:53 AM
Sentra Spec-V Electronic Throttle Control Sensor...thingy.... jiggydragon Dallas Nissan Enthusiasts 9 Jul 1st, 2005 02:49 PM
Car isn't working like a normal car Blackk Magikk General Discussion 17 Jun 23rd, 2005 02:26 AM
Need help with a car buying decision, sell my 240z turbo to buy a Sentra SE-R Turbo? bast525 B13 91-94 chassis 8 Mar 24th, 2005 10:27 AM
