Old Feb 7th, 2006, 06:02 PM   #1 (permalink)
sicksilver99
Send a message via AIM to sicksilver99
oil disapears! help!
Since i changed my oil last fall i started losing oil and i didnt know why. my car didnt seem to be burning oil and i checked for leaks, but i lost like a quart every month.that was the first time i used a fram oil filter, and also my auto teacher said that fram oil filters are so good at filtering that if they have bypass valves the oil bypasses the filter most of the time. so i thought it was the filter and i changed my oil a month ago using an stp filter. the oil didnt disapear until yesterday i noticed about a 1/4 of a quart was gone. its not as bad as before but its still a problem. whats going on? how can i tell if my car is burning oil?, and what should i do?
<click here to see car> mods- cat back exhaust, driving lights, sony xplod stereo, audiobahn 10" subs, sylvania silverstars/ future mods- custom cold air intake, timing advance, amp for subs, headers
sicksilver99 is offline   Reply With Quote
Old Feb 7th, 2006, 09:56 PM   #2 (permalink)
79kz400
There is a rectangular oil seal inside the valve cover that is a known cause for this. I cannot find the old post but if you search "oil" in this section of this forum you might find it, the post was last used about 3 months ago. It has the dealer part# in the post so you don't have to guess. I paid just under $6 @ the dealer.
The seal measures about 1" x 2" and is rectangular in shape.
79kz400 is offline   Reply With Quote
Old Feb 8th, 2006, 12:37 AM   #3 (permalink)
JeenYus
Really common problem with this engine is the front seal leaking. I'm not sure it could come on as quick as it seems to from you or not. A good way to check if you're burning oil is to look at your tailpipe. If it's got a lot of black soot like stuff, you might be burning oil, if it's clean, you probably aren't. Again, that's a pretty crude way to check, but can be a start.
JeenYus is offline   Reply With Quote
Old Feb 8th, 2006, 04:32 PM   #4 (permalink)
sicksilver99
i found that section and the part number. how can i tell if that seal is bad? if this seal is bad then where does the oil go?
i'm definitely not leaking oil cause i park in the garage and there is nothing on the floor.
Old Feb 8th, 2006, 08:57 PM   #5 (permalink)
79kz400
good find!
When I started this post I assumed that the newer GA16DE has the same seal as my '91 B-13 sentra. Someone correct me if i'm wrong on this one.
I don't really know where the oil goes. I guess that it enters an intake valve and is burned.
Only way I know to find out if its bad would be to take the valve cover off and look at the seal. If its all @$%&@'ed up or looks funky replace it.
Mine was sort of squished/wrinkled in the middle but in decent shape overall. Some members are reporting that the seal was all rotten and came off in chunks.
You may consider replacing the valve cover seal while you're there if your motor is nice and clean.
Hit up the $tealership. While you're there save yourself some time and price a new front main seal. Yep. I know yours dosn't leak... yet. AutoZone wanted $44 and the local dealer got me the part for $6.85. Dealer's prices may vary.
Would you please post a link to the thread you found the part# on?
Old Feb 8th, 2006, 10:03 PM   #6 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Fram makes the WORST filters around. Your shop teacher is wrong about them being good. I would't put one on ANY motor I own, my lawnmower included. Use an OEM or a WIX filter.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Feb 8th, 2006, 10:06 PM   #7 (permalink)
SuperSentra4203
Post Freak
SuperSentra4203's Avatar
I agree, Fram sucks. When I worked for Advance Auto Parts, Honeywell (Fram's parent company) sent us a warning about Fram filter being used on certain vehicles, such as Nissan, Toyota, and newer Chrystlers. I always stuck with either AC Delco (for my Grand Prixs) Purolator Pure-One (for my Nissans and DSM) and Mobil 1 (for my Trans Am).
1996 Cutlass Supreme SL (not stock) 1 of 2 CS's w/ Grand Prix HUD and Dash!!
Mods - Custom Catback w/ Dual Flowmasters, Custom 3" FWI, 17" ADR Rims, SilverStar Conversion, Grand Prix HUD Swap, Grand Prix Dash, GMPP Trailing Arms, Carputer w/ Lilliput 7" Touchscreen, Kicker ZX200.4 Amp, HP Tuners MPVI Tuned
http://i50.photobucket.com/albums/f3...wserwerwer.jpg
SuperSentra4203 is offline   Reply With Quote
Old Feb 9th, 2006, 08:36 AM   #8 (permalink)
sicksilver99
i meant that he said that the filter was so thick that it gets clogged up easy.
i'll be sure to check that seal. the link is here
Old Feb 9th, 2006, 10:22 AM   #9 (permalink)
79kz400
Its OK sicksilver99. Thats the publik edukation system fro ya'
If you want more info on oil and filters go visit http://www.bobistheoilguy.com/
Old Feb 13th, 2006, 04:00 PM   #10 (permalink)
sicksilver99
ok i finally had some time to take the valve cover off(first time) and check that oil seal. i dont think i found it. there was a rectangular looking black thing on the yellow piece on the valve cover, idk if thats it or not but it looked good. does anyone have a picture of what this seal looks like?
Old Feb 15th, 2006, 08:52 AM   #11 (permalink)
jer28
Nissan Fanatic
Okay, go to this thread and look at the second picture. You will see the hole for the gasket above the oil dipstick. If we are talking about the same thing here.
http://www.nissanforums.com/showthread.php?t=116964
jer28 is offline   Reply With Quote
Old Feb 15th, 2006, 04:07 PM   #12 (permalink)
sicksilver99
ok thanx , one last thing, do i need to replace the valve cover gasket now that i took the valve cover off?
Old Feb 15th, 2006, 04:22 PM   #13 (permalink)
jer28
Nissan Fanatic
I would, and I believe that most people do. Remember to use a thin coat of rtv around the distributor.
Best Engine Oil???? MCHNHED B14 95-99 chassis 70 May 15th, 2008 05:21 PM
when to use a synthetic oil leerob58 Truck & SUV 15 May 19th, 2006 12:18 AM
Limited time showing, come one come all!! Marvin Off Topic 43 Jan 14th, 2005 07:35 PM
Checking Engine Oil - Too High? Josh GA16DE 1.6L Engine 10 Aug 10th, 2004 05:23 PM
Changing Oil GlowstickBoy Off Topic 5 Aug 8th, 2002 11:07 AM
