Old Jan 27th, 2006, 03:49 PM   #1 (permalink)
deadlyrays
Send a message via AIM to deadlyrays Send a message via MSN to deadlyrays
Going Nuts
Need to know where this hose is leading to.
http://photobucket.com/albums/c397/d...current=77.jpg
that hose goes down under the intake pipe and connects to this black plastic box, on the otherside of that black box a small tube connects to the valve cover. What is this black box and is it important, if not can I leave it dangling with the big hose unhooked to anything.
Some have said its a breather box and that I need to put a breather filter on it when i put my aftermarket intake on, some have said its the resonator and that i can just leave it unconnected to anything. Read this clearly, it will not fit onto the aftermarket intake, the nipple on the aftermarket part is toothpick skinny while the stock hose from this black box is obviously larger as you can see in the picture. I will seal that nipple off with silicon once i know what this black box under my intake is.
deadlyrays is offline   Reply With Quote
Old Jan 27th, 2006, 06:08 PM   #2 (permalink)
azkicker0027
Cone Dodger
azkicker0027's Avatar
Send a message via AIM to azkicker0027
looks like the trans breather hose. got a better angle?
Naturally aspirated autocross car.............naturally.
http://members.cardomain.com/azkicker0027 And defending STF in the process.
http://www.200sxonline.com/community/
azkicker0027 is offline   Reply With Quote
Old Jan 27th, 2006, 09:47 PM   #3 (permalink)
deadlyrays
ill try tomorow morning, its very hard to get the angle of the box. if it is can you tell me what i can do about it once the new intake is on. connecting it to the new intake is not an option.
Old Jan 28th, 2006, 03:00 AM   #4 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
It is a resonator. It shold not connect to the valve cover at all. The VC breather hose connects to the intake. You shold be able to remove the ENTIRE box.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Jan 28th, 2006, 11:25 AM   #5 (permalink)
deadlyrays
ur sayin it shouldnt connect to the valve cover at all but it does You said the VC breather bose connects to the intake, so when i put the new intake on, can i leave the breather hose hanging there. I really dont want to remove this box because if its connected to the valve cover and intake, im kinda scared its gona fuck something up.
Old Jan 28th, 2006, 12:34 PM   #6 (permalink)
Slayer2003
Peek-a-boo....
Slayer2003's Avatar
Send a message via AIM to Slayer2003 Send a message via Yahoo to Slayer2003
Yep, it is the resonator. Moreover, it was an added water catch-all for Nissan. The hose you are talking about going from the intake, to the valve cover, should be a vent line, and its to the left of the hose you circled in the pic, just before the throttle body.
Now, on the BACK of the resonator, there looks to be a vaccum line running to the transmission possibly, but I can't really tell from the images Nissan FAST is showing me.
Originally Posted by RoadWarrior - ocforums.com
Yes, SATA is faster however..... putting full spec formula one tires on a 1.6L stock honda civic will not make it capable of 200Mph......
SEARCH BUTTON. USE IT OFTEN!
Slayer2003 is offline   Reply With Quote
Old Jan 28th, 2006, 01:06 PM   #7 (permalink)
deadlyrays
when i put the new intake on, can i just leave that big hose hanging there unconnected to anything. ????
Old Jan 28th, 2006, 03:36 PM   #8 (permalink)
wes
Wise Cracker
wes's Avatar
Why have you not yet at least tried to install the upper pipe. Things will make more sense when you try the install.
JWT
www.notnser.com
Old Jan 28th, 2006, 10:36 PM   #9 (permalink)
b13pnoysentra
Nissan Fanatic
That looks like the center wire in the distributor cap. OHH nvm, ur mentioning the intake pipe. My 94 has 2 big pipes (one to the VC, and one behind the ECCS) The smallest pipe on mine is as thick as a coffee stirrer and leads somewhere to the bottom of the car.
b13pnoysentra is offline   Reply With Quote
Old Jan 29th, 2006, 01:58 AM   #10 (permalink)
deadlyrays
the upper pipe is on wess, just didnt know wtf i do with this exposed hose
Old Jan 29th, 2006, 11:43 AM   #11 (permalink)
wes
Wise Cracker
wes's Avatar
SHow us a pic of the intake installed and how the resonator box attaches to the VC. Worst case take the hose from the resonator that connects to teh VC and just tee it into one of th ehother hoses on the intake...
JWT
www.notnser.com
Old Jan 29th, 2006, 01:10 PM   #12 (permalink)
thestunts200sx
Nissan Addict
P.S. Have you concerned cleaning your engine ??
Just a thought.....takes like 5 minutes ....
TheStunts200sx
People that owe me money and/are SCAMS::
R1autodesignwholesale
thestunts200sx is offline   Reply With Quote
Old Jan 29th, 2006, 02:52 PM   #13 (permalink)
azkicker0027
Cone Dodger
oh you mean that part of the intake duct that has that screw clamp on it. i was looking at the smaller pipe.
When was the last time you were hit in the nuts? Hendrix Off Topic 30 Sep 16th, 2005 08:50 PM
Nissan Lug Nuts Pranav General 240SX/Silvia/S12 200SX 4 Feb 19th, 2005 09:21 AM
on my nuts! krylonkoopaa Off Topic 22 Sep 1st, 2004 02:17 PM
Recommended Lug Nuts G_Funk013 General Discussion 2 Mar 2nd, 2004 04:14 PM
need 00/01 altima lug nuts danoh New Member Forum 1 Jun 13th, 2003 07:32 PM
