Old Jan 22nd, 2006, 01:30 PM   #1 (permalink)
jer28
Nissan Fanatic
Tach signal (no I'm not hooking up a tach)
I am in the process of troubleshooting a car. Two questions...
1.) I thought that the tach signal wire had an AC frequency which changed depending on engine rpm's. Meaning the frequency would increase or decrease depending on if the engine was at 1000 rpm's or 4000 rpm's.
2.) Is the signal different from the distributor coil negative wire and the output for the tach wire from the ECM/ECU/PCM?
Can anyone help me out on this one?
jer28 is offline   Reply With Quote
05 b15 need tach signal 99NissanAltimaRyder B15 2000-2006 1 Dec 21st, 2005 10:19 PM
Symptoms of a Dead Tach? sentrastud B11/B12/KN13 82-90 chassis 10 Aug 8th, 2005 10:45 PM
Tach Swap Signal Question sentrastud B11/B12/KN13 82-90 chassis 1 Jul 24th, 2005 01:19 AM
Full notes: B12 tach gauge cluster swap Galimba1 B11/B12/KN13 82-90 chassis 13 Mar 25th, 2005 08:19 PM
Missing tach signal! sentragtr20 S13 240SX 1989-1994 4 Oct 27th, 2002 10:01 PM
