Replaced Thermostat--Now Car Won't Start - Nissan Forum
post #1 of 6 Old Dec 11th, 2005, 09:39 AM Thread Starter
TJS
I just replaced the thermostat on my 92 Sentra (GA16DE engine)--not exactly the easiest component to get to... Anyway, now when I try to start the car, the engine cranks but won't start. It seems like it wants too, but never quite "catches".
First, the thermostat I installed (Stant Superstat P/N#45758, the part recommended by Advance Auto) did not have an air bleed valve like the OEM part.
Second, I'm not sure I did a good job bleeding the system when I refilled the coolant.
So, is it likely that one of the above is the source of the problem?
Thanks.
TJS
TJS is offline
post #2 of 6 Old Dec 11th, 2005, 01:45 PM
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Thanks.
TJS
No neither matters. You can start a car without coolant and it will run.... There are two small grounds on or near the thermostat housing, did you remember to hook those back up?
wes is offline
post #3 of 6 Old Dec 11th, 2005, 06:40 PM Thread Starter
TJS
Thanks, Wes. No disconnected ground wires and car still won't start.
B.t.w. I had disconnected the wiring harness for the temperature sensor on the thermostat housing, but I reconnected it (double checked). I don't see any other wires connecting to the housing. I checked to make sure there were no loose wires in the vicinity as well.
Is it time to call a repair shop?
Tim
TJS is offline
post #4 of 6 Old Dec 14th, 2005, 05:26 PM
Nissan Addict
nastynissan's Avatar
Send a message via AIM to nastynissan Send a message via Yahoo to nastynissan
First things first..... Pull a Spark plug.. More than likely it'll be soaked in GAS. If so pull the other 3. More than Likely the Engine Flooded. If your plugs are wet... Take them all out, Pull the Fuel Pump fuse, and turn the engine over a couple times. Reinstall plugs, and Fuse.
BEFORE Turning the switch on, Push and hold the Acclerator to the Floor, Crank the engine while still holding the pedal down. Once it fires you should be able to keep it runnung and it'll clear up after a Minute or 2.
As some of us know the GA16DE has problems with flooding itself ocassionally. Ive had them do it a couple times after a thermostat repair. Possibly from an air pocket by the CTS??? You can try doing the Second part without pulling the plugs first, Sometimes it'll work.
****Nothing worth saying or showing****
nastynissan is offline
post #5 of 6 Old Dec 14th, 2005, 05:47 PM
Nissan Addict
Good advice....im actually gonna write that down...
People that owe me money and/are SCAMS::
thestunts200sx is offline
post #6 of 6 Old Dec 19th, 2005, 03:39 PM Thread Starter
TJS
I finally got back to the car yesterday. When I went to pull the plugs I found corrosion on the connectors of two plug wires. Replaced all 4 plugs & wires--voila it started like a champ. Thank you very much for the assist!
TJS
TJS is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
HELP car wont start Burn 17 B14 95-99 chassis 13 Nov 29th, 2005 11:09 AM
CAR WON'T START - HELP!!!!! gfriedman L30 1998-2001 Altima 3 Nov 7th, 2005 07:22 PM
Ok so my car didnt start this morning.... BigGreg85 A32 1995-1999 Chassis 1 Oct 26th, 2005 07:33 PM
1989 MAXIMA WON'T START AFTER WATER HOSE FROM WATER PUMP REPLACED reyesstars New Member Forum 2 Sep 17th, 2005 01:17 AM
help with my 94 maybe Fuel leak? /bose/bad idle at times/ac heat? And handling? DonaldHays J30 1989-1994 Chassis 3 Aug 16th, 2005 07:56 AM
You may post new threads
You may post replies
BB code is On
