Loosing fuel pressure when off. - Nissan Forum
post #1 of 14 Old Nov 28th, 2005, 09:55 PM Thread Starter
I have been having starting problems suddenly with my 93. Lots of cranking but no start. Like it wasn't getting fuel. So if I but the ignition to on and let the fuel pump prime the system, it starts fine. So what would cause the fuel pressure to drop while sitting. It only takes a few hours of sitting to start having issues.
Thanks
turboawd is offline
post #2 of 14 Old Nov 29th, 2005, 12:47 AM
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
Thanks
Is yoru gas cap OK? I ALWAYS let my fuel pump prime before start up! Anyways many cars will bleed off fuel pressure over time as they have a fuel return, this is normal and should not necessarily cause hard starting. Are you sure the problem isn't something else?
wes is offline
post #3 of 14 Old Nov 29th, 2005, 01:35 AM
Nissan Fanatic
Burn 17's Avatar
Send a message via MSN to Burn 17
he is very possibly right, try letting you pump produce pressure befor cranking it over, to do this just bring the key to the on position for several seconds. i do this everyday just to ensure a quick start, my car also loses presure but there is no problem with that.
By the way dose the car actuly start?, eventualy?
Burn 17 is offline
post #4 of 14 Old Nov 29th, 2005, 12:40 PM Thread Starter
Yes it will start fine if I let the pump prime for 20 seconds. But I never had to prime it before this problem started and it used to start pretty easily. If I don't let it prime now it cranks forever and eventually starts. Then it runs rough for a while and then is ok. I will check the gas cap is on ok.
turboawd is offline
post #5 of 14 Old Nov 29th, 2005, 08:24 PM
Replaced your fuel filter recently?
79kz400 is offline
post #6 of 14 Old Nov 29th, 2005, 09:08 PM
Nissan Addict
nastynissan's Avatar
Send a message via AIM to nastynissan Send a message via Yahoo to nastynissan
Problem A==== Fuel filter
Problem B==== Fuel pump dying..
Ive only experienced it on Nissans, but often when the vehichle is haveing fuel issues on start it turns out to be the pump... I think its because they use a higher voltage initially to prime the system. After that it drops off unless you need extra fuel Ex. WOT. Check the filter FIRST though... Then run a Fuel Pressure test..
****Nothing worth saying or showing****
nastynissan is offline
post #7 of 14 Old Dec 2nd, 2005, 01:53 PM
You might check your fuel lines. I recently had the same problem as you on my '91, and found some small cracks in the fuel hoses. I wasn't losing fuel physically, but it was drawing air into the system. Replacing all the hoses solved the issue.
Bob
RallyBob is offline
post #8 of 14 Old Dec 5th, 2005, 12:10 PM
Nissan Fanatic
Burn 17's Avatar
when you say you let it prime for twenty seconds, do you actuly mean that the pump runs all twenty seconds? if so you most likley have a presure leak in your hoses. i would first look at all the fittings and conections by your filter, fuel rail, and all the way to the back of the vehicle evently. i hope you find a simple fix. good luck
Burn 17 is offline
post #9 of 14 Old Dec 22nd, 2005, 10:37 AM Thread Starter
Still having hard start issue as well some slight idle surge and poor gas mileage. The other strange thing is that the cooling fans start running right away when the engine is dead cold at its -10C. The A/C is off. I'm thinking the coolant temp sensor or air temp sensor is faulty. Would this make the ECU think its hot and causing the cold start problem?
If the coolant temp sensor is faulty, would it not trigger a check engine light?
Is there an aftermarket coolant temp sensor available?
Thanks
turboawd is offline
post #10 of 14 Old Dec 22nd, 2005, 12:27 PM
Nissan Addict
Thanks
Your CTS being faulty could definetly cause the Starting issue... Normally when a CTS goes bad the ECM see it as COLD (like -35). This will cause Excessive Fuel to be dumped in and give you the poor mileage...
And yes this "Should" trigger the CEL but on pre-OBDII models its not always a Definite. Check Haynes, Chiltons, or FSM for exact testing procedures.
post #11 of 14 Old Jan 3rd, 2006, 11:18 AM Thread Starter
Looks like the coolant temp sensor is gone. Reistance was very low on a cold motor. Like I said before, both rad fans are always on regardless of A/C switch on or off. Will coolant spill out when I try to replace the sensor ?
Also, looks like the TPS is also gone. Not sending any voltage. I measured 5v at the harnes but almost nothing through the sensor even when rotated. The car still runs ok but not great with these two problems and no check engine light ? Is there an aftermartet TPS? If not what does Nissan want $$ for one ?
Thanks
turboawd is offline
post #12 of 14 Old Jan 3rd, 2006, 07:17 PM
absolutely classic
Kindfiend's Avatar
Thanks
The fans running all the time may mean your ECU is shot. Mine was, but the CEL blinked in morris code sometimes at first, then all the time until I replaced the ECU. It had nothing to do with the coolant temp sensor like I thought at first. I didn't measure resistance, I just replaced it since it was a cheap part and I like piece of mind.
Nissan charges about $100-150 for the TPS, I believe.
Kindfiend
01 Sentra GXE
92 SE-R
Kindfiend is offline
post #13 of 14 Old Jan 6th, 2006, 02:14 PM
Post Freak
sunnysentra's Avatar
your fuel pressure is maintained by the pressure regulator to hold. Now the return lines send the fuel back when the car is turned off. The pump churns up until the regulator hits the pressure and then the pumps turns off at the right pressure.
If you have a leak its in the line connections. Old fuel lines will leak at the connections eventually.
Chris
Part of the AUTO / MANUAL SWAP CLUB
sunnysentra is offline
post #14 of 14 Old Jan 31st, 2006, 09:39 PM
Some possible things to check for hard starting:
Leaking fuel lines.
Faulty fuel pressure regulator.
Leaking injector.
Defective pump.
Good luck.
Maxtrax is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
New fuel pressure regulator design: Opinions Please synapse Forced Induction & Nitrous Oxide 16 Sep 1st, 2005 03:20 AM
Correct Fuel Pressure for the QG18DE ericvai777 QG18 1.8L Engine 1 Jul 11th, 2005 05:11 PM
Fuel pressure regulator velardejose Forced Induction & Nitrous Oxide 0 Jan 10th, 2005 01:05 PM
how to check fuel pressure? Katana200sx GA16DE 1.6L Engine 0 Sep 27th, 2003 11:40 PM
Installing 300zx Fuel Pump into a B14 holy200sx GA16DE 1.6L Engine 10 Jul 2nd, 2003 04:33 PM
You may post new threads
You may post replies
BB code is On
