Old Nov 20th, 2005, 09:32 PM   #1 (permalink)
b13pnoysentra
Nissan Fanatic
Fuel Filter
What brand is the best OEM style fuel filter that I could get for a 94 Sentra GA16DE? What prices should the range be in? I thought of buying from the local nissan dealer but, I know they will probably charge me a lot.
b13pnoysentra is offline   Reply With Quote
Old Nov 20th, 2005, 10:26 PM   #2 (permalink)
nastynissan
Nissan Addict
nastynissan's Avatar
Send a message via AIM to nastynissan Send a message via Yahoo to nastynissan
Actually dealers are getting closer to afterrket prices... I myself use NAPA Gold filters.. I believe Wix makes them.
****Nothing worth saying or showing****
nastynissan is offline   Reply With Quote
Old Nov 20th, 2005, 10:32 PM   #3 (permalink)
ReVerm
Boxed Fox
ReVerm's Avatar
If you really care about having the best filters on your car, go for the Wix or AC Delco ones. Their oil and fuel filters are designed pretty well. You're looking at up to $8 (a couple more dollars than the cheaper brands) for one filter, depending on where you get it. Thankfully, you'll probably only go through one a year.
Captain Slow.
Old Nov 21st, 2005, 11:15 PM   #4 (permalink)
b13pnoysentra
Nissan Fanatic
I just had an oil change and used a wix filter with 10w-30 castrol syntec synthetic. And I found the wix fuel filter for 19.97 plus tax at a local parts store. Just removed the screws and tubes and replaced the 11 year old stock one and put everything (hoses, clamps, and screws) back in their place, but didn't reset the ECU or anything. Is that okay? It seems to work fine without disconnecting the negative terminal.
Old Nov 22nd, 2005, 02:25 PM   #5 (permalink)
wes
Wise Cracker
wes's Avatar
Send a message via AIM to wes
I would certainly have disconnected the negative from a safety perspective, but not for resetting the ECU.
So since you didn't blow yourself up then don't worry about it.
www.NissanPerformanceMag.com
JWT
www.notnser.com
Old Nov 22nd, 2005, 03:28 PM   #6 (permalink)
b13pnoysentra
Nissan Fanatic
After reading sentra.net, the goal of the battery shut off was to depressurize the filter. When removing the old filter, some gasoline spilled out of the tubes and the old fuel filter. Just cleaned it up with some rags and made sure everything was dry. I know gas ignites and I'm glad my dad doesnt smoke like some of his friends when working on cars.
Old Nov 22nd, 2005, 04:42 PM   #7 (permalink)
Madmaxfl
Madmaxfl's Avatar
NAPA has great filters but I like to use the Nissan fuel filter. I think the last one I paid about $15. It is also the same filter i use on my 85 Z so I usually keep a couple around,
Madmaxfl is offline   Reply With Quote
Old Nov 23rd, 2005, 08:33 PM   #8 (permalink)
yuke
I just bought a puralator #F43178 from advance auto for $9.88.I think if you take the fuse out for the filter it will depressurize the system.
yuke is offline   Reply With Quote
Old Nov 23rd, 2005, 11:51 PM   #9 (permalink)
makaveli
Nissan Fanatic
theres a fuse for the filter? thats why gas spilled out when i changed mine! i only took the fuse for the pump out
makaveli is offline   Reply With Quote
Old Nov 24th, 2005, 09:29 AM   #10 (permalink)
nastynissan
Nissan Addict
NO..... the fuse if for the Pump... Your suppose to "start" the car after you pull the fusee to De-presurize the system. The car will normally sputter and die when you tryto start it without the Fuel Pump Fuse. Do this 2-3 times and THEN pull the filter..
Fuel filter fix? sfsentra GA16DE 1.6L Engine 1 Oct 13th, 2005 01:20 PM
94 Sentra fuel filter kelly boy GA16DE 1.6L Engine 6 Sep 17th, 2005 06:50 PM
Fuel Filter Rama GA16DE 1.6L Engine 6 Jul 4th, 2003 01:42 PM
Hidden fuel filter? Raul B13 91-94 chassis 8 Dec 16th, 2002 11:19 AM
Fuel Filter mjohannsen U13 1993-1997 Altima 6 Nov 28th, 2002 10:15 AM
